car inspection
Guest neoGT-25
 Share
Guest neoGT-25
Hey all :)
I have found a nice A31 NISSAN CEFIRO for sale... only problem is, im in qld :D
now, before i buy her, i want to get it inspected and possibly compression tested (are compression tests worth doing & how much?) Since im in qld, i wouldent have a clue who to get it tested by and i have heard that RACV arnt very good with import inspections??
could someone please give me an idea of who to go to? web-links? phone numbers? anything like that! ;)
please please please help!! :wavey:
thanks, Cameron
ps: yes my speeling is bad, thats cost its 9:37am :)
Its in QLD .. RACQ up here will do inspections, but same problem as VIC in that they might not fully know imports. It will be expensive also if you are not a member. Could try giving them a call, and they'll be able to fax you the results of the test.
Compression test is the same procedure no matter what vehicle, but its just a bitch of a bitch on the RB20's as you gotta pull a few bits off which they don't like doing.
The number for their bookings service is: (07) 3361 2700
`read it again u qld pig traitor
edited so he didnt think i was talking to him and being rude :(
Guest neoGT-25
mmmmm that black one on performance forums is almost exactly what i want BUT its 4wd :)
but
i can make it rwd cant i?
nah its not one of meggalas cars or oyabuns.
thanks for the advice people :D i will check this one in briss out :(
lol.. you want a drift car don't you?
At $9k -- even with an autoconversions would be a good deal if you ask me.. at the time you can also get the RB25DET box put in which will be heaps stronger anyhow. I'd say at a guess the fuse would be possible as it uses a similar ATESSA system to the R32 GTR from what I've read.
Guest neoGT-25
i see
i will look into it!
problem is... the one i found in melb has much better bits... inc a 2way mech lsd, manual conversion, heavy duty clutch, hks pod, turbo timer, strut brace, drift wheels (16"), 2x cat back zorsts (one mild steel, one stainless) droped on springs too...
byes :(
 Share
    • So, after talking to Tyson at Auto Tech Engineering about my "cunning plan", he suggested to "not piss money away on stuff that the car probably doesn't need" (the max IAT at the end of the 1/4 ever only seen around 30°C, which is in no way a issue, and as such, for what I use the car for I really don't need colder IAT anyway The whole point of the "upgrades" that I thought about doing was that my IAT started creeping up from 25°C to 30°C when cruising, then drop back down, then raise back up, rinsing and repeating, it has never done that before, so after talking to FI interchillers they assumed that it was the Bosch pump starting to fail, and if I was going to replace the pump....... I would do my usual thing of "while where in there" But, Tyson said he has seen similar things happen to IAT with failing or leaking AC compressors on other cars with interchillers, and as the AC compressor is 22 years old it is probably well on the way out anyway, and if a electric water pump fails it stays failed and doesn't just speed up and slow dow, but if a AC compressor starts to fail or is leaking, it will fluctuate and give a typical result to the IAT He said he could test the compressor and see how it is functioning and pressure test the whole system, but, as I do, I've just got them to order a new compressor to install to start with, and do a AC service and see if that fixes the issue That way, if it is the compressor, I wouldn't be spending lots of coin on something that wasn't the issue, and not actually needed, as the stage 2 kit, and pump, comes in at around $2k in parts alone, not including the plumbing and other parts that will be required or labour  And apparently the Bosch pump I have is really reliable and well up to task for the flow/pressure requirements that I need to keep my intercooler and massive amounts of boost heat (7 psi LOL) under control giving a nice and cold IAT A big shout out to Tyson for this, not many people will talk a idiot out of wasting money on car modifications, and the saved car budget funding can be wasted elsewhere on things that I may, or may not, need, like a nice new leather SS interior with red stitching......maybe I can convince the Minister for War and Finances into a nice trip down to Victoria for a week away to see the sights (I'll explain that I will need a hire car once we're down there so we don't have to worry about the Commodore being parked up on the streets at night, and it just so happens there's a joint that I can store it during that time) $1680 for all of the interior trims, + installation cost (I'll ask for a quote to install the trim if the new compressor fixes the issue)   https://leatherseats.com.au/products/leather-seats-trim-skins-kit-to-fit-vt-vx-vy-ser1-ss-green-black-diy-install
    • Anyone here know the answer?....missing since the w/e...
    • Google tells me that's a Japanese Rat Snake... 2m long? Man I think Australia has traumatised me to think all snakes are dangerous unless they're pythons. Also... "16 years later..." is that a record on SAU @PranK?
    • Yep, I really miss mine. I dont, however, miss it's understeer. Hard to find a genuine 'Sport' model these days. That sounds awesome! Good fun and great result!  I'd love to do a 1/4 in mine now that its reasonably healthy with the tune. I last did a run in my white GTR, I think it was a 12.3 and I can't remember the mph and I think the little E90 might be quicker.
    • FWIW, I made 372kW on a Mainline dyno, with a stock motor (bar head studs & usual bolt ons) on E85 (pretty timid timing in the mid range) and it blew up after a year of track use. Probably got like 5~6 Wakefield track days and 1x skid pan somewhere in between.
