I just bought this exhuast.
It's a 3.5" Inch HKS exhaust but I don't know what the internal pipe diameter is.
When they quote an exhaust as being 3.5" does that mean that the internal pipe diameter is this width? or is it smaller?
lol even if the outer diameter of the pipe of a 3.5" pipe was 3.5" you'd only be losing literally a couple of millimeters of diameter due to the thickness of the pipe itself
in conclusion it's completely negligable.
If its 3.5 i would be confident in it fitting, like i said, the HKS is slightly over 3.5inch anyway. They are 95mm (for R33 anyway, 34's appear to be 85mm)
Have you considered measuring the pipe yourself? That way you will know for sure wont you.
Okay so i'm trying to find out which ecv to buy to match my exhaust.
Apexi ECV - http://www.nengun.com/apexi/exhaust-control-valve
155-A014
Nissan - Type A - ID 67mm - Bolt 105-107mm
155-A019
Universal - Pipe Type - ID 80mm - Bolt 105-107mm
Anyone have any ideas?
Thanks mate, but I cab by measure the pipe because its in transit. I've seriously got no idea which ecv will fit.
i can't answer your question, but i will just point out that if you are putting in the ECV to make the car legal, it technically won't be. if the car ever gets tested they test the exhaust with the valve open. if you are putting it in to at least reduce the amount of attention the car draws and make it quieter to drive, then go for it.
Yep, i know that it won't make my car legal.
The problem is that i don't know which ECV will fit my 3.5" inch exhaust?
Nengun supplied the attached info sheet, and i asked them what the internal pipe diameter is but they haven't got back to me.
You can see that i've highlighted in red the area i'm trying to figure out if it's 89.9mm (3.5"inches) to see if it will fit my exhaust.
Anyone have any ideas or experience?
Edited by R33-RB26DETT
I think it says 67mm. You may have to go for the round slip on ones, the 80mm should be close to sliding inside the 3.5 inch pipe and the 95mm would be the only choice for larger than 3.5 inch, it would need adapters on each end. Perhaps you could hide it inside the cat body?
I believe pipe diameters are quoted as "inside diameter". So a 3.5" pipe has an internal diameter = 3.5".
this would make sense as different materials used for making exhausts would have different thicknesses depending on how strong they are
Ah well, i just ended up ordering this one
155-A014
Fingers crossed it fits, i'll post back here to let others know because it was seriously painful getting the right answers anywhere.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
