31 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 308
Posted Images
wow thats actually in really good shape ...
What's your opinion on the corolla atm?
it seems to drive well, only problems are
Right brake light not working
Dash - top half of the plastic is missing
Cracked headlights on the front
Aircon not working
It needs a CV Joint
That model DOES have a left side mirror so will need to put one on
Passenger windows winder thingo
The immobiliser he may be able to pay for ...
I also found a radiator hose and timing belt in the booth .. :s
Should I pass it back to him or just try and get him to pay for the immobiliser if hes willing?
That civic (red one in my list) was alright, good shape and all ... but a bit too new i like old cars LOL
the auto 88 corona is pretty nice, good interior and all .. HAS AIRCON
the celica is sporty and quite cool
cant decide if i should return the rolla and try for one of those (bet half of em are sold knowing my luck) or just stick to my rolla and get the immobiliser on
Yeah the things wrong with the car are not big problems though I should fix the brake light asap
He did say he was willing to take the car back as he didnt know the actual age of the car and so just randomly put 1980 so he said that was his bad .. if i return the car/get the immobiliser on i'd pay for half of it I reckon cos he was real fair to me and stuff so yeah
voted for corolla johnno.have owned three.2 78's and a 79.reliable,easy to work on.speeding car hit me and the rolla's chassis saved my life.plus got $500 bucks for the motor after the car was munched.+1 ke rolla
you could get that red civic james? it was pretty good imo im just not into civics ..
richard - id love a KE corolla, their all gone though, the one i saw was 800 bucks for very little ...
Currently mainly considering a 89 Celica/88 Corona (auto :( ) or my 86 Corolla Sedan ATM which may or may not be returned to owner tomorrow unless he wants to chip in for the immobiliser
I'll let you guys know tomorrow what happened to the car!
Maybe I should hold up for a really good KE Corolla or something ...
I want something to play with in my uni break though! thats only 2 weeks away .. and I should study for exams now actually ...
Bob the bunky is gone
I asked the owner if he wanted to go halves on the immobiliser, he said he'd rather just wait until the car was 25 years old and didnt need an immobiliser anymore so we swapped back confused.gif
Yeah I think he also said something about the car he was gonna buy had a major problem so he would need a car anyway so it actually worked out well .. im thinking of spending a bit more .. mayb sumthing with aircon for my pampered ass thumbsup.gif
Did KE corollas have A/C?
Ah ok, makes sense haha.
And no lol, no AC.
I just checked out a suzuki swift tonight, no AC no PS no central locking, no tacho, no EW.
Car was immaculate though lol. 1.3L carby and all.
$1850, pretty damn tempted cause its that good... Even though missing lots of luxuries...
Decision time..
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
