Hey everyone, simple one, I'm looking to see who recommends what engine builders here in SA.
I've dealt with Lewis Engines before, but wasn't super impressed, plus i've heard mixed reports. Ideally looking for a Nissan specific builder. Someone who takes care and has the right equipment to build a reliable RB.
I have heard of Allen Engineering in Mallala, and apparently they know their Nissan engines.
YES i'm on a budget, i dont have unlimited $$ for this, at this stage i'm looking to chat to the builders, decide on one, see what engine components they like to use, order them, then give him my head and block and let them work their magic.
Give me your opinions, thanks.
NOT LOOKING FOR ANYTHING INTERSTATE. Thanks.
https://www.sau.com.au/forums/topic/365947-top-notch-engine-builders-in-sa/
I used Rhemac for my machining, they also do assembly also, however they are a bit pricey. Other then that I would suggest Lewis Engines, I shall be using them for my head work.
Boostworx, and Willall also do assembly as far as I am aware.
Yeah i have heard of Rhemac, and have just been speaking to a mate about them. But yeah he said they are quite pricey.
What machine work did you have done and what was the rough bill?
I have used lewis before, and yeah wasn't too greatly impressed. Plus i've heard some horror stories as of late too.
Check out my build thread :thumbsup:
but to give you an idea
Hot Tank Block and Crank
Grub Screw Crank
Mirco-polish Crank
Bore and Hone Block
Line hone block and girdle with torque plate
Check Rod and Crank Bearing Crush
and a few other things...all up it was just over $2.2k
Also, if you want top notch, your going to pay for it.
I'll be using Lewis as my tuner is friends with them.
go visit James from Nispeed, he is a Nissan performance engine specialist up at Modbury just down the road from Morpowa
if u can track down Peter Hall (ex Willall) he is also one of the best, they both built my forged rb25
im now at Morpowa
Wow Aberax, a little pricey yes. I had similar work done to my RB30 block for half the cost through lewis engines, but eh his work wasn't that great.
ovrtym33 - I've heard of Nispeed, but havn't really heard about their work. I know Peter Hall and have heard of his work, a mate also got his bottom end work done by him, and neither myself or my mate were overly impressed with what he did. I think Peter's knowledge is well and truly L series stuff. But i might have a chat to them anyway. Plus Peter is impossible to get a hold of.
Can you elaborate on this? Did you have a personal difference or was the machining sub standard (if so in what way).
I had my motor built at Boostworx, and havent had any issues with it at all.
its been going strong for 2.5years now and for the last 18 months its been a 300+kw RB26
When I was building mine all that time ago i asked Manta what they would charge and it was a little steep for me.
But boostworx came within my budget
It wasn't that bad, i just think hes more a get the job done as quick as possible, get it out. I dunno maybe it was his attitude. I've also heard some not so good stories about other people. Apparrently he built an engine, rod failed due to not being correctly torqued, but he blamed it on the tuner - being pre-detonation. Customer got no warranty or anything. But yet it was a workmanship failure, not tuning.
Boostworx, hmmm yeah nah, i'm sure they do alright, but they send their machining work to someone else as they are a performance workship, not a dedicated engine builder with all the necessary gear to build engines.
I've just been on the phone to Allan Engineering, he seems to know his shit! For the power i'm chasing, he really thinks i should stick with stock rods, JE or CP pistons, change the exhaust valves and a few other things, nothing too major for the 400kW MAX that i'm chasing.
Also spoke to knight engines, hes not too sure about using a Tomei pump, he seems to think the stock pump with billet gears are good, hmm i'm not too sure about that. But he said the same, JE or CP pistons, he said stay away from eagle rods, go with something like a SCAT rod (which Allan said not to). But he was also saying something similar that i wont really need to do heaps of head work and such to achieve the power i need.
If you call every workshop in town you're going to get mixed thoughts and just end up confused.
Ahh yep! I was aware of this lol.
Just spoke to Andrew from Rhemac, he seems to certainly know his stuff! Hes gone against the other two and said that Eagle rods are fine for the power i'm chasing. So there another mix up there.
But he also said for the power im after, head work isn't really necessary, just do a rebuild, bronze vavles, valve springs etc.
Rhemac /thread
Had work done by them but very impressed, timely, always keep in contact and excellent work. Maybe a bit more pricey but you get what you pay for. Best thing about them they won't oversell stuff just for you to spend more money there.
I also had a bad experience at Lewis Engines, piss poor attitude, terrible excuses and couldn't deliver when given AMPLE time. Stay way away imo. Ask Matty T about his headwork, see what he has to say
Rhemac /thread
What work did you have done Heslo?
Yeah i know Matty T very well, im good mates with him. And i heard his horror story with Lewis, lifters all needed to be reset.
What specs is your RB26? You do track work and it hasn't failed yet? Power output, engine specs etc?
I got my head fully rebuilt, ported, polished, etc. Had some Tomei Poncams fitted at the same time. Apart from that and the oil restrictor mod my 26 is internally standard,puts out 320awkw everyday @ 18psi and hasn't skipped a beat. I put a lot of that down to supporting mods like oil cooler and most importantly the tune. Touch wood I haven't had an issue yet but when I do eventually rebuild ill get Rhemac to do the bottom end also.
I've always had the motto spend a little more now to save later or the poor man pays twice. Going with this philosophy I've had a trouble free car modifying experience and a tonne less headaches. Sure it might cost a bit more but as I said earlier you get what you pay for. Can't afford it now? Wait! Youll kick yourself in the head later down the track when something does go wrong
Anyone got more information on James from Nisspeed? Does he do his own machining? Head porting?
YES IM PRETTY SURE HE DOES ALL HIS OWN MACHING AND ALSO MANY PERFORMANCE WORKSHOPS USE HIM FOR THIS REASON
HE DID ALL THE MACHING FOR MY ENGINE THEN PETER HALL ASSEMBLED IT
Yeah good point, hence why i'm getting a good builder to do it. Not like an average one like Lewis.
Do you remember exactly what work he had done to your head, cam specs, lifters, retainers done? Valve guides/seats etc? Oh and if you dont mind me asking, what did that sort of end up costing you?
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
