hi guys,
I have a 34 GTT Catback exhaust with Nismo silencer muffler $300
R32 Gtr gearbox push type has done 80,000kms $600
Rb25 Alternator $50
Rb25 Starter motor $40
Rb25 Air con pump $40
Pm any questions or offers
No response from person making offer as yet, so they are still open to first person with cash to purchase them...prefer Melb pickup but can organise shipping at buyers expense.
Still available bidder hasnt made contact since offer...$500 for gearbox pickup in Melb $300 for Exhaust...postage to Sydney/Queensland can be organised PM for price
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
