How do you get caught with engine numbers being ground off? If you grind them off and restamp them then there is nothing to get caught with, grind it smooth and there is no evidence.
roy is right there is some sort of x-ray they use it doesn't matter how smooth you grind it will come up with marks to show it may or may not of been grinded and if they think it's sus they impound your car and if they have to rip out your engine to get a better look they will and that's in SA
  • Replies 110
Posted Images
Dunno if its been said already, but when you order a new RB20/25/26/30 block from the factory, the flat face where the engine number is stamped is a clean flat surface with no engine number on it. It is expected that the buyer/builder of the new block stamps the required engine number into the block. Hence, the ownus is on the builder to stamp the "correct" number on the block.
There are tests to reveal if the "grind & re stamp" process has occured. However, I'm yet to hear of a single story of anyone modifying their car in such a way and receiving this kind of treatment.
Edited by R32Abuser
I am going on what I have been told, I think they do mag particle test or something. You need to machine a fair bit off to get to a level where you can stamp the new number without any metallurgical evidence that there was an original number there. The give away is the hieght of the casting where the stamp is.
Seen it done ages ago, i think they used acid etching. Similar to how they recover serial numbers that have been ground off guns. The stamped area of the metal is denser and the acid eats away the less dense metal and reveals the serial number.
i never modified the engine but bought a stolen and recovered 300zx z32 from nsw brought it down to SA they thought it was sus imponded the car and i didn't see it for 6 weeks cause they had to check engine number hadn't been re ground, everything wa fine of course cause nsw had cleared it but SA transport just wanted to be cops
I am sures its not common. But the point is:
1) Its wrong to say that you can throw an RB25 in your car and just re-stamp the engine block with your RB20 number hoping nobody pics the plenums etc
2) If you throw an RB25 in your car you depending on state, have to have a certified engineer look at the conversion. The catch is they will look at everything, not just the transplant, So if they are not happy with your ride height, exhaust, ECU, front mount location, intercooler, carbon fibre bonnet etc then these can all be stumbling blocks to getting engineering
There are ways around it and compromises...we should maybe post up a tutorial thread by those that have done it from start to finish in respective states.
+1 would be good to have a run through of what people have done to get there conversons engineered...only other option is to be mates with an engineer lol
I'll make a thread about my experiences in SA if you want. With engineering you can't just get any old engineer to sign off on it, they have to be a mechanical engineer, they have to have chartered status and then they have to be certified by the RTA to sign off on things, even then they often only get certified for certain things, eg chassis mods, engine mods, etc.
Edited by Rolls
Make it look as stock or unassuming as possible.. no high mount this, no bling that..
what bout relocated oil filters and braided lines i heard some where that there not legal...is this true??
In SA I would call regency park as they handle all defect and modified car inspections etc, find out who the equivalent is in your state and call them, they will have a list of all ADRs and be able to tell you what is required to make it legal.
I imagine the concept of an external oil cooler/filter is not illegal (why would it be) but it is more the issue of it being improperly installed and causing injury to a pedestrian if it leaks or somehow causing a fire hazard.
You could also try calling a registered automotive engineer in your state that can sign off on engine/car modifications, I'm sure they could point you in the right direction, would probably be far more helpful than the gov organisations as well.
exposed pod filter wouldn't help the cause up here...
Over here it just needs to be secured by two brackets. It's not going to remain exposed either, once I'm done with the shakedown the pod will be getting covered and I'll make up some custom heatshields for the manifold and dump.
As for oil coolers/filter relocators, I would imagine that as long as your fittings and hoses met the relevant AS for pressurised fluid couplings (no idea what that is) and as Rolls mentioned, the installation isn't dodgy, there shouldn't be an issue?
That is really the main thing that I have found with modifying cars, if you do it properly - and it shows (quality welding, well thought out mods, no dodgy corners cut) then things will generally go a lot easier for you.
is there anyway to engineer a lowered riding height? or is it just the minimum height and that's it...cause the minimum heights here in SA for 32's is gay it's 345 for front and 355 for rear which gives it a gay raked look and would much rather it 335 all round cause that sits nice :D
http://www.infrastru...n/vsb_ncop.aspx
this is the document you want
http://www.infrastru...n_2011%20v3.pdf
mainly these bits is what you have to comply with
"When lowering a vehicle, the ride height of an unladen vehicle must not be changed by more
than one third of the working travel of the suspension from its original height to a rigid bump or
rebound position specified by the manufacturer. The suspension bump and rebound positions
are measured with any deformable bump or rebound stops removed. The original relationship
between the front and rear suspension heights must not be changed and therefore the front and
rear suspensions must be both raised or both lowered by the same amount"
You must also not exceed the minimum clearance which I believe is 100mm from the lowest part of the car. Also if you change suspension geometry in the process this has to be rectified.
Edited by Rolls
There was a good post ages ago by SK back a few years that explained the point of having the 32 sit at the legal height. Regardless of looks, the 32s suspension doesnt work the way it should with excessive wear on bushes (more so than even the std height wear). Given the roads in 99% of au are not the best (unless we live in canberra :rolleyes: ) i dont know why someone would want suspension that would give a rough as guts ride, as well as f**k out your bushes so damn fast, other than "it looks fully sick bro"
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
