and again today! Dude you just moved into the neighborhood or what? I see you most days now...
BTW, be careful driving around Curtin. We have lots of international students who either cant drive or shouldnt drive (legally) but do, and its dangerous as shit. iv avoided about 20 accidents (not kidding) over my 3 years there and also been cleaned up once.
silver R35 GTR. Seen you 3 times in the last week around Curtin in Bentley. I was in my red R33 gtst twice n my black R33 with Jun kit on it once.
Good to see a GTR getting driven how it should be :thumbsup:
Spotted 3 differant R33s on marmion, wanneroo and burns beach all 3 tried to race me which kind of got old a friendly wave responded with a revving of the engine, just because I'm on P plates doesn't mean I'm a hoon :/
Anyways white one with a jun bodykit I think was nice but sitting in the limiter in second isn't a good idea, sounds cool and all but eh...
Dear Unlucky owner of a white 33 gtst whom has been caught on armadale road tonight im guessing booze bus,
im feeling your pain as i drove past your car already on the back of the trailer of the truck they had ready for all their victim's for tonight
Gun metal grey R35 GTR in Bicton - on View Terrace to be exact turning down Westbury Crescent
I wasn't jealous at all :P
Oh and for what its worth, over the past 4 weeks have seen a Black Ferrari 599, Black Ferrari F430, Black Ferrari 458 and a Green Lambo, all at the Canning Hwy and Riseley St intersection! (Applecross)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
