  • Replies 76
Hi mate I sent u a pm last night but no reply.
I need the nismo gauges or stock ones, whatever you have and the square radio bracket if u still have it. Also do u have the climate control unit?
Need posted to melbourne. No teenybopper messing around. :)
I don't know if you have an auto or manual but would you have the auto gear surround,the stereo surround and the three gauges on the top of the dash of the 34 ? if so consider them sold
Hey there, would love a pic of the genuine Impul front bar, been hunting for one for so long, ill take it off your hands straight away, would just like to see a few pics and some pics of the damaged section... VERY, VERY interested in this item, i'll definately grab a few other things that you might have left aswell if i get this bar, cant wait to hear from you, Cheers..... Elle
hey,
would you happen to have the part that connects the rear window washer to the hose where the water comes from. its like a plastic thingy and kind of looks like the head of a penis haha
mine broke and so water just sprays all in my boot ):
post-77335-0-34690800-1307956925_thumb.jpgthats mine with the bit broken off ): and the bit that connects that to the hose.
also i will probably want the rear parcel shelf.
and a few of those plastic screw thingys that you find in the boot.
theres some whacky stuff for ya :D
im trying to think of other things i would want haha
may have it but in a spare rear windscreen i have. will have to get up ther and have a look.
i have a parcel shelf in good nik,
also have quiet a few plstic trim holders from boot.
will pm you my progress.
nat0
also found both reverse lights, thought i ost them but now have matching pair, one has crak in mounitng bracket
i bought some sh ones to get me outta trouble but the are alive.....
Edited by nat0z
i think he said that he doesnt have the din pocket, but not to hijack the thread i do have an aftermarket single one for nissan if someone is intrested.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
