feel free to recommend to me a panel beater that does good work and wont charge me a fortune
woman backed into a wooden pole and has trashed a rear panel :*(
darwens have quoted me 700 bux, im hoping i can get good work done, but cheaper than that (getting front bar resprayed while we are at it)
preferably southside, inner city
https://www.sau.com.au/forums/topic/36718-panel-beaters/
I'm also after names, places etc for the work i need done .. when i do finally get it done :D
Don't want to drive to 50 places to get quotes so some recommendations by people would be a great help. Probably needs to have worked on skylines, and needs to do a very good job.
https://www.sau.com.au/forums/topic/36718-panel-beaters/#findComment-732748
In Brisbane?? this is QLD and QLD specific thread.. but yeah, when i was in melb already been to palm.
DMD does good work, their pretty busy but ask them or another place called wizard smash repairs
DMD is not the sort of place I'd take my car to get painted for this sort of thing. May need a small dent popped out on the door i've got on anyhow.
https://www.sau.com.au/forums/topic/36718-panel-beaters/#findComment-733526
Dr Kustom (Shawn) - does the best prices in Brisbane from all the places I've found quotes from. Tell him Bryan recommended you and I'm pretty darn sure he'll take good care of your ride at a very affordable price.
contact: 0402 637 642 - panel shop is in morningside
he doesnt advertise and owns his workshop - thats why he can do such great prices.
https://www.sau.com.au/forums/topic/36718-panel-beaters/#findComment-733568
He gave me a ball park figure to which i am not posting because he really did not want to commit to a certain price as he wanted to inspect the vehilce first and then give me a definate price, bit hard to explain just how bad my roof is so he wanted to have a look at it first. Which is understandable.
https://www.sau.com.au/forums/topic/36718-panel-beaters/#findComment-734949
Camerons at coopers plains got the job
mainly coz they were the ones that originally painted my car (street machines blue) so it made it easier to match the colour
plus they were cheaper by over hundred bux on the next cheapest quote
plenty of nice imports there being worked on also
https://www.sau.com.au/forums/topic/36718-panel-beaters/#findComment-738671
zoixy dude, bugger all
ive done pretty much what u did (ripped front bar off, i just had mine tied on with cable ties)
would only be a couple hundred to get it resprayed and reattached propperly
especially if camerons already did your car, means they got your colour ready to roll
https://www.sau.com.au/forums/topic/36718-panel-beaters/#findComment-743152
I paid about $350 for my frontbar to be painted and fitted from raw.. but i was getting some insurance work done at the same time so they may have charged me cheaper.
My 400R is 110mm off the ground, but I've got adjustable coilovers.. Depends on your setup? I definitely wouldn't go much lower than that, its already JUST bareable on most QLD can throw at it.. but it will die an eventual death.. I give it another 12-18 months till it needs replacement. If you go low and actually drive it, front bars are a throwout item.
https://www.sau.com.au/forums/topic/36718-panel-beaters/#findComment-744191
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
