I've looked at this thread a few times and am considering doing it to my 33 instead of a Nismo style lip which is more expensive and I'm not really sold on.
Has anyone been running one long term? Or did everyone give up on these??
hey man, I bought my rubber lip from ebay a while ago, couldn't tell you the exact vendor but there's heaps on there
held on just using double sided tape and still going strong after 6 months through the winter, rain & highway driving
if it starts to fall off, which I don't see happening anytime soon I can always reapply double sided tape
Huh? I thought Amazon don't do anything to Australia, only to US?
A year or two ago I had to get the stuff I ordered on Amazon shipped to a specialist outside-US shipping company and then onto myself - comGateWay.
Amazon is the largest online retailer on earth - pretty sure they can post internationally.....It's a brave new world out there!
I just got confirmation yesterday that it's en route and have a tracking link, so will let you know if it makes it!
The stuff off ebay is totally different to the ones I bought lol. The ones of ebay is THICK and stiff, compare to the ones from Amazon, is soft and bendable, hence why the ebay ones would start to fall off because it's too heavy and when you drive, it fights against the wind :)
Of course Amazon send stuff to Australia, but just depends on what. You are half right though, there's a lot of stuff they don't send to Australia. But the lips isn't one of them :)
I just found a new spare roll at home, if anyone wants it for $25? PM me
Update.
Mine lasted 4 days before the stuff ripped to shreads going into a servo, it was double sided taped and screwed on.
My cars ride height from the lower part of the bumper to the groubd was 160 mm, so not overly low.
I did look good for 4 days though but served no other purpose as it was too flexible for any form of aero.
A waste of money is my official opinion.
I should have bought 6 pack with the money.
High speed runs was not the problem, I went to the drags and got a 134 mph trap speed and it held fine.
The problem is the spongy/soft rubber compond it is made from, as soon as it grounded it tore all of the RHS off and chewed out the rest, the top of it was still attached to the bumper, the lower section of it was dragging behind.
There was only about 400mm of it on the LHS that survived unscathed.
Be wary of any slightly steep driveways or inclines.
  • 4 months later...
finally got around to doing mine.
Haven't seen a black 34 do it yet, so i took my chances lol. went really well, though i wish i had an aftermarket lip that I could've put on and then put this garage seal one on. looks kind of plain.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
