Item Summary: ISC Coilovers suit R32 gtr or gtst
Spring rate is front 8kg rear 6kg perfect for street or track use, very comfortable street driving.
Asking Price: $800 ONO they retail for $1200 + post atm save yourself $400+
Condition: used, 4 months old
Delivery Methods: PickUp or Post at your expence
Contact Info: 0420855181 PM or [email protected]
Extra Information:
32 Step Damper Adjustable
  • Precise control damp valve
  • Operates smoothly on all road surfaces
  • Expansion/Suppression of shock adjustment
Pillowball Uppermount
  • Adjustable camber allows more/less on road track for all conditions
Piston Rod Design
  • High rigidity steel piston rods
  • Meets with race/sport standards
Sports Spring
  • Made from high quality SAE9254 steel
  • Tested over 500,000 times on compression inspection with less than 5% deformation.
Ride Height Adjustable
  • Full length height adjustable
  • Bound adjustable with separate spring locks
  • High quality T6061 aluminium alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
Aluminium BracketMade from T6061 aluminium alloy by organic shaping to lighten weight and increase handling performance
  • Specifically anodised surface to prevent inside corrosion and surface rust
  • On various models camber can also be adjusted via the bracket aswell as the camber tops
Single Cylinder Design
Larger cylinder and piston design to advance driving stability and dexterity
https://www.sau.com.au/forums/topic/367374-isc-coilovers-fr-8kg-re-6kg/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
