1 Michael Schumacher Ferrari 1:33.074
2 Mark Webber Jaguar-Cosworth 1:33.715
3 Rubens Barrichello Ferrari 1:33.756
4 Juan Pablo Montoya Williams-BMW 1:34.054
5 Kimi Räikkönen McLaren-Mercedes 1:34.164
6 Jenson Button BAR-Honda 1:34.221
7 Ralf Schumacher Williams-BMW 1:34.235
8 Jarno Trulli Renault 1:34.413
9 David Coulthard McLaren-Mercedes 1:34.602
10 Cristiano da Matta Toyota 1:34.917
11 Felipe Massa Sauber-Petronas 1:35.039
12 Giancarlo Fisichella Sauber-Petronas 1:35.061
13 Christian Klien Jaguar-Cosworth 1:35.158
14 Olivier Panis Toyota 1:35.617
15 Nick Heidfeld Jordan-Ford 1:36.569
16 Gianmaria Bruni Minardi-Cosworth 1:38.577
17 Zsolt Baumgartner Minardi-Cosworth 1:39.272
18 Giorgio Pantano Jordan-Ford 1:39.902
Ahhh fark - I was gonna watch it 2 nite - now i don't need to....... Bummer.....Shite.....
Maybe next time, results like this can be posted in another thread so we have the option to view or not - ???
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
