Hey I'm getting my Ps in 2 weeks just in time for this cruise!
I am fairly unfamiliar with you guys so I was wondering, would you guys mind me tagging along on this cruise. ? And Is it okay to bring a mate along too?
Just thought I would check with you guys first, didn't want to rock up unexpectedly haha. If you don't mind me asking, how old are you guys? Coz I'm 17, theres no age limitations or anything right? lol
Geezus I cant wait to be rolling in a pack of Skylines :D
Hey dude,
Iv'e been doing these cruises with Gemma, Owen, Terry, Joel and the rest of the bunch since I was on my L's Brought mum along :P cause thats how I roll. I'm also on my red's and will be more then happy to chill and talk with you, It's a bit awkward at first but everyone is really freindly and are there to have a fun, SAFE time.
If you havn't done the Pass before, May i suggest you Stick near the back With Me :P haha don't wanna get in the Way of the turbo's.
Oh And guys there is still the 80Km/h Roadworks on the freeway Heading Down just off the On Ramp :).
See you all there!.
  • Replies 163
Posted Images
Hey dude,
See you all there!.
OOOFT YOU DID IT ON ON YOUR L's? respect haha
and yeh thanks man, i was a bit worried at first when some1 mentioned fast corners. but its good to know i can tag along at the back with you. biggrin.gif lets hope i pass the driving test! pinch.gif
Hey dude,
See you all there!.
:(:( Ill be at the back back!!! God i miss miss my turbo:( Ohg well maybe one day:) But hey, i can live vicariously thou you guys until that day comes:)
I'll definatly be coming....cannot wait lol, its been soo long since i went on a good cruise...the last one was the R32 Bday cruise : ) ...
HEY UR SHERONS BROTHER!! HAHA i asked him at school if u were going, he said he wuld tell u.
HAHA He told me about your new car..welcome to skyline ownership!! lol
well im definatly goin, im not missing this cruise lol. ill see you there..
I should be able to come
Alot of you don't know me, I tagged along with owen last year.
I got my gtt and blacks now, I should be able to make it for good food and company :)
Is that school meeting point where we first parked last year on an angle and took photos for the south coast people??
yeah thats the plan mate. we want to meet up in front of the school @ 11:30-12pm. sydney crew should be down by then
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
