I noticed yesterday that my clutch is leaking a lot of fluid from where the shaft (the one kinda attached to the clutch pedal) goes into the master cylinder.
I'm guessing a seal is gone, but can anyone offer up any advice asap. Is there anything I can try short of taking it somewhere because I'm a bit short on funds atm :
Thanks
46n2
https://www.sau.com.au/forums/topic/36757-help-asap-cluch-leaking-fluid/
Funnily enough - I found that exact problem today as well. I have clutch fluid dripping down onto the clutch pedal and the floor. It's not leaking very fast but I had to top up the fluid today - I caught it when it was about 2mm from the bottom of the fluid reservoir.
46n2 - is the fluid leaking inside the car like mine?
MearCat : Yeah, it's leaking inside the same as yours :D I've spoken to a few ppl and they think i'll be in need of a new master cylinder. I'm holding off for a few days to confirm. I'll post back and let u know...
46n2
  • 4 weeks later...
  • 7 months later...
nooooo. $250 ouch....
in future guys.....
go to your local clutch place. and ask for a rebuild kit. should be about $10.
it will be a rubber seal. then you just replace the rubber seal on yours. and bolt it back in.
thats all that is needed to be done. i had a problem on mine and i solved it this way.
if you dont want to go to the hassel of rebuilding it...
i have got a spare one i'd sell.
it doens't leak. i doubled up when i didn't know what to do...
hehe...yeh i've got the same problem.....always a wet patch on my floor mat under
clutch pedal...and refillin the clutch master cylinder every couple of weeks.....
anyways...like dabigbolf said....i went and got a rebuild kit from nissan...
only cost me $40..
kit contains complete piston, return spring, piston stop ring, o-ring and the boot - all brand new....
if you going this way best idea is to give the cylinder a nice honing to insure the seal beds
in smoothly..
$250 is a bit steep....so $40 and a lil diy is ALOT lighter on the wallet......
Clutch Master Cylinder.
$250 is a bit of a RIP.
I bought mine for around $60-$70 from a local brake/clutch shop in St. Mary's.
It is made by PBR.
I may be able to dig up some old photo's of the box & part number.
Bl4ck32 also recently replaced his and knows the exact price as I replaced mine 2.5years ago.
Also guys remember when taking on the $40 kit rebuild option - IF your master cyl has scores in the bore it will need to be re-sleved or replaced which will end up costing you more money in the long run.
So before you buy the kit - it may be a good idea to take the master cyl off and taking it to a clutch place for assesment before spending your money.
I have encounterd the same problem on another car we had used that was 15 years old and from japan.
Does the clutch slip when powering down from 1st to 2nd when you shift really fast, once you back off quickly ( when you noticed its slipping ) .and give it gas it stops slipping ?
If thats the case, your stopper for the clutch pedal can be the problem.
petar.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
