No commercial stake in this (although I'm racing in the series this year). Just an interesting option if you haven't raced before and don't want to pay.....
http://www.chanceofalifetime.com.au
Basically, pay up, you get one day timed sessions at Wakefield. Person with fastest average lap wins.
I'll be going to the 24/10 session as Kelly is entering that day, and am happy to help any other SAU ppl who are interested in giving it a go.
Ive seen that advertised in autoaction and talked about it with other people who race karts, is seens a bit dodgy to me, think about it there are so many things that affect lap times temp, tyres etc and also if you have raced/driven a particular type of car you are abviously going to be quicker that someone who steps in even if they are a better driver. Bit of a gamble to me.
true, they try and keep it even by
5 * 5 lap runs in each of 5 cars
Drop slowest session (if you stuff it)
Tyre pressures can be adjusted
Only get compared against others from your day's heats (to rule out day to day temp changes)
And the Daewoo one is for novice (non-CAMs license) only.
I ran this the other year, seemed fair as it could be to me, and I highly recommend it. As for karters, all three who won a season last year are ex-karters...
How did the person who won the konica drive go?, the others dont really lead anywhere but would be fun to do. I dont think you would get the best equipment, personnel etc which dosent matter for the one make series but would make a big difference in konica. I heard all bad stories about the guy who won a formula ford drive through the kartstars and a free drive cost him a fortune.
The bloke that won the Konica drive was Grant Johnson, running 10th in the series. You're right, it wasn't the fastest car out there, but it was still a free season, and 10th is pretty good in a series that competitive. They're planning on buying a new car next year too, as all the top V8 cars will be replaced due to the new regs.
The other two who won last year are:
Ben Morley, 3rd in MGs and
Robert Dercole, 1st in Daewoos.
As far as costs, its just damage to the car - it cn add up if you're not careful, I'm paying on average $500/round for that.
:D
  • 3 weeks later...
Hey Pete,
If you read this can you PM me?
We're heading down for COALT on Wednesday night and looking to get a cabin at the place next to the track (Pelican Sheep Station). I think the deal is 4 people stay for around $60, so let me know if you want to shack up with Duncan and I.
Kel
Originally posted by Kel
Despite having heaps of fun, the best I managed was a mid-field finish.
There was the small matter of overtaking all three cars in the first session though.
Zoooooooooooooom.
"Where the hell did she come from?"
:eek:
(PS no-one lend her your keys - I now know how she treats borrowed cars)
Hey Flip,
You might be too late. check out http://www.chanceofalifetime.com.au, I know they have already started the trials, but I think there is one more in December
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
