we've all wasted money on cars over the years,spent many hours only to have sold the car at a later date at a huge financial loss.....old classic cars always hold a good dollar so this time im rather excited with my current purchase,this genuine 1975 mazda GT rx3....I bought old granddad mazda from japan and he has had quite a few nasty paint jobs over the years,although he is in pretty original condition.So here he is just arrived ready for his return to youth make over.....its getting stripped to a bare shell,bead blasted underneath/inside and outside,repainted and fitted with a period correct mazda factory racing 12a peripheral port engine,although it will have throttlebody injection hidden underneath the standard aircleaner :).....now old pops would have been a bit of a stud in his day,being mazda's "sportscar" of the seventies,the RX3 gave a shake up to the gtr in the japanese touring car class spoiling nissans chance of 50 wins in a row and for some reason appears to be the most desirable model.....so here is a bit of nostalgia for the younger guys to show them it wasnt about how loud your stereo was,how bright your neons are or how silly you can make your car look with 50 inch wheels.....it was the begining of the era that got the boys with V8s worried and taught them the meaning of respect and killed off the term "jap crap".
https://www.sau.com.au/forums/topic/367749-mazda-rx3gt-restoration/
  • Replies 89
Posted Images
Please please please don't put simmonds rims on the car...like every other Capella/RX2/808/RX3 out there
I love these cars
PP 12a will be awesome!
i think that when these cars are built up to keep with the theme of old mods simmons are something that was used in the old days so to make the car period correct they get used.....or those old jelly bean wheels/dragways....its not like you can put newer wheels on .....i dont think there is much choice
ok heres the rear seats back after retrim.....someone had changed the front seats over the years so had to find those(found now) and they are still getting done.....75 GT's had these funky washers in the centre insert and leather was also an option which the owner took on my car....Im also about to build up the factory race engine with a bunch of new old stock stuff i got here....i will post the pics when i get going on it
I can't believe for the same money I paid for the GTR 8 years ago I could have bought 3-4 RX3 coupes. Now good luck getting one for a reasonable price let alone finding one.
Nice score. Will be fantastic with period mods and a nice 12a PP!!!
Can I ask how you sourced the car in Japan? Aren't the locals buying these up as well so finding one for export is difficult?
yep hindsight is wonderful huh?I do know of 2 other GT rx3 coupes in japan for sale (one of which i painted over ten years ago!) and familia coupe (r100) so they are around and for sale.
I look around here and found nothing but 808's converted into rx3's with autometer tacho's,roll cages and autobarn race seats for no less than 13k was the very cheapest....on the other end 30k for gen rx3 but with again roll cage/turbo engines but nice cars....just not original/period correct....im about to start building the engine....for those that dont know these first pics are the "engine cylinders/block and camshaft's" all in one and these are mazda factory racing units.I will show some pics of the engine being assembled as i go
mazda factory racing inlet manifold and injection throttle body.The throttle body is a direct bolt on to any manifold that takes a webber/solex carb and converts to efi.I dont think i will be using the trumpets as they dont really fit the era of the car
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
