  • 2 months later...
  • Replies 98
hey buddy letting you know im not a scammer i asked for a standed r32 GTR turbo that was ingood working order and has no turbo play and what did i get , i got an r32 gtr turbo that and been high flowed by atleast 5 mill so clearly not standered dick head and it had a f**k oil line , huge spilt in it whitch means the turbo had been running with no oil at some point and it needed a rebuild , so clearly not in good working condition , so i thought f**k you , you can wait to get you dodgy as f**k turbo back , ohw and your POS TURBO SHOULD BE AT YOUR DOOR STEP BY NOW SENT IT TO YA LAST WEEK
Edited by tranf4m
https://www.sau.com.au/forums/topic/367999-tranf4m/page/2/#findComment-6025248
Biggest douchebag holy shit, somebody ban his IP so he can't rip anyone else off on these forums. Strangely enough I make it a rule not to deal with people who A) Can't type for shit and B) Use their own fonts, colours and sizes instead of the standard.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/2/#findComment-6025712
look at it how you want cant do shit i sent peace shit turbo back to him,i hope he resel the heap of shit to one of you f**k heads ... if he had of sold me what i wanted in the 1st place whitch he SHOULD OF COCK SUCKERS wouldnt of had this issue . think about it
https://www.sau.com.au/forums/topic/367999-tranf4m/page/2/#findComment-6026780
Haaaaaaaaaahahahahaa you're a f**kin douchelord.
That is all.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/2/#findComment-6026880
f**ken oath. Some people are just f**ked. I tried to buy a turbo from a guy on here several months back and he simply just wouldn't post it. He kept asking me over and over if I had the money. f**ken dur, would I go shopping with no money? But then some people on here are good as gold. Like a young fella called Don (skyzthalimit) that sorted me out with a fuel pump, a z32 afm and a profec A boost controller. The pump and the z32 are still going strong and the boost controller was rooted. I called him up and he said "No worries man just come down and I'll refund your money". And he did. If I had to fly somewhere to get my shit back it would be a motec tune with anti-lag, traction control, flatshifting and individual cylinder correction. And I would run it on the dyno till it popped.
Subscription in the mail.
https://www.sau.com.au/forums/topic/367999-tranf4m/page/2/#findComment-6027333
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
