Hey guys and girls, well it is a sad day indeed for me. I am selling my GTR as new baby is here and there is now a need for me to get a somewhat normal family car (Prado in this instance) and also because my back just aint what it used to be after surgery. Never mind though because what is a sad day for me could be a very happy day indeed for someone else who is in the market for a genuine 32 VSpec II.
OK so here is the run down....
I have owned this car since it was imported in 2008 and it has never missed a beat. It is not 100% standard as when imported it already had some modifications done (see below). It is only used as a daily driver to and from work and on the occasional cruise. Always garaged but it does have some minor blemishes from stones being flicked up etc, basically the stuff you can't avoid happening to any car but I just don't have the time to fix it.
Ok so here are the list of mods:
- full Kakimoto exhaust including front pipes
- NISTune ECU (running safe 240RWKW on 1BAR boost tuned by Trent at Status/Chequered Tuning) can also throw in a consult cable and laptop with the nistune software on it if needed
- Apexi pod filters (have standard airbox with K&N panel too)
- Apexi Boost Gauge
- Momo Steering Wheel on a works bell slim boss kit (have slightly worn standard wheel too)
- AUS Spec Tein Super Street coil overs with Nolathane Upper camber kit fitted 1 year ago at Centreline Suspension
- Nismo twin plate clutch with lightened flywheel
- Nismo front strut brace
- Full Nismo body kit incl full side skirts, rear lip spoiler and bonnet lip
- Car is running EBC Redstuff ceramic pads on factory Brembo brakes
- has darkest legal tint (35% tint-a-car Midnight Express)
- Standards Approved alarm/immobiliser
- Pioneer CD with iPOD control, front splits, rear 6inch speakers, removable boxed sub in boot, 4 channel amp plus monoblock amp for sub.
Car is regularly serviced and maintained with Synthetic oils, have receipts for all australian modifications made. No accident history. I will obtain a RWC prior to sale this way you can be assured that it is current.
Any more Q's give me a call or shoot me a PM.
Jarrod 0402-316-156
PRICE IS $26900 ONO
https://www.sau.com.au/forums/topic/368233-1994-r32-gtr-vspec-ii-for-sale/
  • Replies 60
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
here are the pics as promised.
Clear coat peel on a pillar drivers side
Drivers seat tear from my jeans pocket zipper
Rear Passenger door trim
Rear Seats (perfectly fine)
Rear Bumper drivers side
Front bumper passenger side
Front Bumper driver side
Side skirt rear pod driver side
Engine Bay
Tein Aus Spec and Nismo strut brace
Intake Plenum
Engine Cover
Apexi Pods (have standard airbox too)
Driver side chassis rails from rear to front
Passenger side chassis rails from rear to front
Any more questions let me know. I know it's not perfect but the issues are very minor.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
