  • Replies 60
  • 1 month later...
still for sale and still no lookers. one guy contacted me and offered 15k. Just to let you all know, if you are looking in that price range, look elsewhere. Don't waste yours or my time. price is $22,000. been on car sales just over a year and only 2 looks
Maybe that means you're asking too much? :whistling:
  • 2 months later...
it's not rough at all just not 100% perfect. the things that are wrong are very minor cosmetic easily fixed but I just dont have the time or money at moment to get it perfect. The KM's are high but the car is a daily driven 18 year old car and at least I am being genuine and honest and not swapping the speedo out in it like a lot of people do..
Anyways, bumpin it up, been a while. Still for sale $22,000 ONO but have a member from here pretty keen coming from Sydney so we will see.
  • 2 months later...
Back from the dead Bump n grind. She's still for sale. No one wants to even look which is a bummer, kms just clicked over 200,000KM.
Supa Spesha Sale time, 10% of the KM's
$20,000 ono
C'mon, make me an offer.
u still selling after1+ years, whats wrong with it ?
also on an 2011 post u said u serviced at 100k now a year later 200k are u saying u put on 100k in a year ?
Edited by Jimmy2Time
Nothing is wrong with it that I haven't pointed out already. It is all very minor cosmetic and is fine mechanically. Your guess is as good as mine as to why it's still for sale, only 4 people have looked at it and only 2 from here. I never said I got it serviced at 100,000km, I got the car 4 years ago and have put 110,000kms on it in that time so not sure where you got those figures from. Car is serviced every 5000 km as it should be.
or in on last years post u said u did 100k service when ur car was showing 169k maybe few ppl confused y u didnt service it ?
In October last year I said I had got the 100,000km service done on it. It was on 190,000km then. The pics in the original post are showing the KM's when the car was put up for sale. I was driving close to 700km a week in it so the km's racked up pretty quickly especially when you add in cruises etc. Once again, the car has been serviced every 5000km.
  • 3 months later...
Okay guys and girls, time to bump. It's been a while.
Still for sale, since last time I was here I have had a few calls but no views. Still on car sales and still in same condition as before. Has just had a new windscreen fitted and usual servicing of oils and filter. Has brand new TPS put on and full set of genuine injector seals. KM are now sitting on 204,000.
PRICE NOW A LOW $17900 but I will sell for less if you don't want REGO & RWC.
Grab a bargain now.
Thread cleaned up. As pointed out, as per forum rules: IF YOU DON'T INTEND TO BUY THE CAR, DO NOT POST IN PEOPLES THREADS.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
