Hi all,
I am about to research pressure washers / compressors for odd jobs around the home (eg cleaning concrete paths, painting, air tools).
I never really considered using a pressure washer for my car as I'm a 2 bucket kinda guy, but if its possible to get units that can do a good job at combining various functions I would like to see what my options are.
I don't really understand the links or differences in pressures or flow rates yet, but any information, experiences or recommendations you can give me would be appreciated.
Here's some of the things I'm trying to establish.
- Brands & Price - Karcher / Gerni / Other?
- Presssure and flow rates - whats strong enough to clean a 30 year old concrete path, and gentle enough for the Skyline (especially around trolly dings / chips), is it variable?
- are these just water or can you use detergents or other (stronger) fluids in them?
etc
As a start point I just rang Autobarn and they stock Gerni. A quick look at the brochure shows a 1740psi / 5.8L/min - 8.7L/min / 1.65kW / 2800RPM for $329. I don't think its a variable pressure model.
Thanks
https://www.sau.com.au/forums/topic/368247-pressure-washers/
I've got a Karcher with the variable pressure lance,(EPC ?) it goes from low, medium and flat out pressures by pulling the trigger within a couple of seconds of each other. I've had it for around 5 years and it's still runs like new, i've used it for doing exposed aggregate concrete, washing drive ways and my car, very versatile bit of kit.
I've got the karcher one that goes for 149 mate, it works well enough - not much in the ways of features though, nothing too special but it gets the job done
Do look for ones with a longer hose length though, it can be alot more convenient.
I would recommend karcher .. I think most of them have filters built inside too? Thats quite useful for preventing lil particles from being blasted at high pressure against paint!
I used to use an 80 dollar GMC one, it worked well enough and i liked that the lance could change the pressure/water flow etc just by twisting it around a bit ... only a 3m hose though
imo at least a 5m :D and longer is better - unless their real sh** quality hoses that just get tangled up anyway! My karchers one seems fine though
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
