So I was exiting out of my mate’s apartment basement car park at Wolli Creek the other day, it has a really steep (30 degree?) and tightly curved sloped driveway which also happened to have a little pool of water at the bottom flat portion of the drive. Now my mate in his stock Lexus IS200 went up this drive as easy as a snake sliding up a fence. Following him, I got like 1-2 car lengths up the drive and couldn’t go further – so much excessive wheelspin and could smell the tyre burning (thought it was the clutch at first).. 3-4 attempts and no luck. I even pulled up the handbrake on the slope, gave it some revs, then dumped the clutch normally, while putting the handbrake down, and still wheelspin at 3,4,5,6k rpms…
Got my mate and another guy to sit in the backseat to get better traction and we only JUST managed to crawl up in centimetres, wheelspinning as before, after the second traction we went up the slope easily, just at the bottom curved bit which was also wet.. My R34GTT has quite firm rear Cusco adjustable coilovers and the front end is a noticeable bit lower than the rear – same Cuscos in front.
My other mate with his stock Nissan Tiida who lives on the block never had this issue before.. So you can imagine them both ribbing me about how my high performance turbo car couldn’t get up that ridiculous driveway when their shopping trolley rides slide up and down like pros.
Anyone got any suggestions as to whats wrong with me not getting traction – hard suspension, front bit lower than rear?? – my tyres are really good – 235/18s, my traction control dosen’t work though, the light in dash is always off.
Maybe I was revving too much, but still? The lexus is a manual and I do know how to drive haha so thats not the issue, I even thought my car is pulling too much torque at low revs causing the wheelspin, but then a lot of you guys are pulling waaay bigger numbers than me and I've never heard of anyone bring up an issue like this..
Your skyline has way more torque than those other cars.
For a steep hill/driveway ( AND WET!!! ) you would need to ride the clutch quite a bit or like you did handbrake start, but dont rev it so high, creep it.
More power = more wheelspin, keep the revs down low, 1-2k range.
Edited by jay-rod
Dunno mate, bought it like that, that was the only thing in my car that dosent work, thats why its pretty dangerous in the wet, even driving it normally, wheelspins very easily, it does have the 2nd traction control butterfly in the intake though, I think either the unit is fuct or the fuse is blown..Anyways I am pulling a kinda healthy 545Nm torque on the stock turbo, tuned to awesomeness by DVS Jez on SAU
My question is - what happened to your traction control system? Anytime I've been in that situation, traction control would kick in and make it fine.
As far as i know Traction control does not stop both tyres from spinning after they have started.
It only stop loss of traction from the beggning.
So if he floored it, traction control can only do so much.
But yes no TCS would not help either :P
Edited by jay-rod
I did strongly think its my stiff suspension, but my tuner said my suspension is beautiful compared to the really hard race-type suspension that he is used to... Could be that my low rpm torque is a bit much for that slippery steep slope..?? The IS200 also a rear wheel drive, didnt have any issue at all, and niether my other mates Tiida - which would have more traction as its a front-wheel drive with the heavy engine in front?
I always thought the R34 has a good front-rear weight distribution although not as good as a mid-engine mounted car, so thought how the hell is the weight distribution causing this issue or is it something else..
i just think you gave it to much throttle.
Have you checked all your fuses? The traction control not working could simply be the previous owner taking the fuse out or it could have blown?
*Edit - If problem persists buy a GTR :happy:
Edited by r32line
Anyone else had this problem? Nobody thinks its my stiff suspension and heavy engine in the front = less grip? I must say its very easy to wheelspin in this car, even in the dry straight roads, when coming on boost suddenly..
Doesn't the traction control system in R34s cut power by closing the throttle body? If this is the case might be able to get up the driveway if you use more delicate throttle control... or no throttle at all
To be honest, I'm thinking either diff or tyres (or a combination of the two). You definitely won't be going anywhere if you are single spinning... I remember trying to drive my cousin's Commodore onto my lawn and I got stuck because all it could do was peg leg!
Stiff springs on the rear end is probably a contributing factor but not the cause
Yeah sounds like you're just giving it too much. Only time I ever had similar in my old 33 was when I had bald tyres, with good tyres you should be able to just take it easy and slip the clutch a little.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
