  • Replies 47
I've raced an autech and it was slower then my rs4s. Maybe just a bad day for the autech but my turbo only held 10psi for 1000rpm before fading down to the poo level of 4-5psi. I think that there may be easier power making mods with the 26 but stock 25 and 26 appear pretty identical.
And hell yes rbd2 I want to see a pic
Is this the same race where you beat a VE SS Sportswagon and your boss's F6?
:rofl2:
jks!
you can easily extract more power out of the rb26 for less $$$$ basic exhaust, more boost and retune should net you 200-220awkw
same mods on a rb25 will only get you 170-180awkw.this of course doesn't take into account the difference in purchase price(which was only $5g when i bought my rs4
i know from personal experience thru the hills, the autech walks away from my stagea and we have the same basic mods, and my car isn't crazy slow either.
If you beat an autech only running 4-5psi then i suspect he wasn't really racing.:thumbsup:
Ironpaw -i understand your joking but go find yourself a ve redline ute and have a race, from 80-150/160 I sat beside him then he crept away. At 180 speed cut his tail lights were only a few meters in front of my headlights. That's the closest race I've had so far. But that said. I miss my stock turbo :'(. Stupid hypergear turbo is driving me nuts.
Big fella - I got mine 4years ago. At the yard an auto was 15990, manual 21990 and 260rs 29990. The only thing I regret is having un replaceable brake pads.
Edited by lilcrash
It drives fine, it's getting a nice consistent 7psi until high in the revs then in a matter of 300/400 rpm hits boost cut 14psi so I can't go above 5000rpm when the cams hit and my car should be going its best basically
Edited by lilcrash
so its boost creeping?
why dont you get a bigger puck welded on and largen the internal wastegate.. mines currently doing it at 22psi.. hypergear said they'd do it for $120 i think.. should definitely stop your creeping issue
It doesn't do it all the time, it's like the wastegate gets stuck open then suddenly jams closed. If you move the wategate by hand it does get stuck but where the sticky spot is it shouldn't open that far.
then your actuator reach is to long.
or you dont have pre load so its already a little opened, so when it completely opens, perhaps it opens to much...thats alot of opens..
i'de be speaking to hypergear as it obviously should be happening.
He said there is no way it would reach that far. It's got about 6mm of preload
get an air compressor connected to the boost signal like to the actuator. and se how many degrees it opens.
to a shop its always a case of "nah will never do that" as they then dont have to fix theyre fault.
if your having issues like that its definitely not safe. hence the reason im on eFlex
The turbo was originally fitted with a high pressure actuator made to hold 18psi. Been told its too strong so I sent him a low pressure actuator. I have no idea how that was fitted as well as the rest of the bits. The actuator only pushes about 60 degrees out of a 33mm disc covering a 30mm gate which's not enough for it to hit the backing housing and if it does jam open then we should see very low boost.
When I sent the low pressure actuator I don't have the turbo on front of me and I don't how long the rod needs to be but longer is always better then shorter, so if its too long then just cut and thread it down to size, and 6mms of preload is way too much, should be 3mm. I don’t get how it can run 14psi then goes back to 7psi. I have a feeling some of the vacuum plumbing is a bit strange or it is too much actuator preload. I'm guiding a novice DIYer and its pretty hard work. :/
The car's needs injectors and a tunned for 18psi. Its not going to make much more power with stock tune and factory boost. And have to say its doing pretty good keeping up with a RB26dett stegea.
I'm in no way a novice DIYer. Most of my job is custom fabrication.
The high pressure actuator gives in stable boost as the wastegate is held open.
There is no vacuum out put on the turbo outlet so I have used the nipple on the next piece of pipe to the intercooler.
Next point. It's got 6mm of preload because that's all the thread that's on there, at 3mm preload it barely had any boost.
I only wish to run 10psi until I get the other parts.
JUST SO EVERYONE KNOWS. THE ATR43SS-1 THAT I GOT FROM HYPERGEAR ISNT CAPABLE OF LESS THEN 16/17 PSI. SO BEWARE.
Edited by lilcrash
    • PayPal is a safe, online payment system that enables businesses and individuals to safely send and receive money, making it an indispensable tool in both personal and professional contexts. However, many users wonder how to send money on PayPal? Don't be alarmed if PayPal is new to you - all the steps can be found by visiting merchant sites with links marked "Pay or send money". Once clicked, select payment method, amount, and add message or note for recipient(s). Upon successful transaction completion you will receive an email containing details of transaction. Let’s start by understanding how PayPal works, how money transfers from banks to PayPal and using various payment methods. Moreover, to transfer money between PayPal and bank, head to the Wallet section and click "Add Account", selecting either "Transfer within seconds with debit" or "Transfer between 3-5 days with bank", and following any instructions shown on screen until completed successfully.   How to Send Money Over PayPal: The Basics Before sending money through PayPal, first create an account. Here is how to set-up a PayPal account: ·         Click “Sign Up” on either the PayPal website or app to enter your basic information such as email address or name into their system. ·         Link your bank account, debit card or credit card directly with PayPal so you can fund transactions directly using these accounts. ·         Verifying your PayPal account will enable you to send and receive more funds. Typically, PayPal requires that you verify your credit card or bank account by making small deposits into it. ·         Once your PayPal account has been established, you can send money through it.   How Do I Send Money to Someone on PayPal? After creating a PayPal account, you can easily send money through it. Here is how to send money to someone on PayPal: ·         First of all log into your PayPal account ·         Once on your dashboard, click on "Send & Request Tab." ·         After this enter the recipient's email or mobile phone number. ·         Enter the amount you wish to send to someone. ·         At last, recheck all the details and click "Send Payment" to complete your transaction if everything looks in order.   How Can I Send Money PayPal for Goods and Services? PayPal provides a safe method for individuals and businesses alike to transfer funds online, both personally and commercially. When paying for goods or services there are additional protections in place both for buyers and sellers. PayPal Buyer Protection offers you peace of mind when paying for products or services with PayPal. In the unlikely event that there is an issue with a transaction, if there are any discrepancies you may dispute it and be eligible for a possible refund. You need to follow the same steps to send money, but select Paying for Services or Goods when prompted. In fact, this extra layer of protection will keep your account safe from fraudulent attacks.   How to Transfer Money to PayPal from Bank? Here is how to transfer money from PayPal from bank: ·         Log into PayPal using either its app or website. ·         Click "Add Funds" in the Wallet section, and add money directly from your bank to your PayPal account. ·         If you have linked your bank account with PayPal, select it under Funding options to select it as your funding option. ·         Enter the amount you would like to transfer to PayPal from your bank balance. ·         Click Add Funds. It typically takes several days for funds to arrive on your PayPal account.   FAQ How can I send money PayPal? Log into your PayPal account, select "Send and Request," enter in your recipient's phone number or email address, select the amount due, payment method of choice and click on "Send Now" - quickly and safely sending money via PayPal is now an efficient method of money transfers!   How do I transfer money to PayPal from a bank? Log into PayPal and select "Add Funds" to transfer money from your bank to PayPal. Select your account number, input an amount, and confirm it. Though the transfer may take up to several days for completion.   How do you send money to someone on PayPal? Simply log into your PayPal account, select "Send and Request", enter the recipient's phone number or email address, select the amount to send, and click "Send Now".   How can I receive payment through PayPal? Senders can easily accept payments with PayPal by providing your PayPal email address and being notified via email when a payment has been completed. When funds appear in your PayPal account, they will appear instantly!
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
