hey everyone.
my 32 rear subframe lower part leaks a little bit after long drives when i stop it comes out slow its like dark brown close to black sticky leak from the bush no one has had this problem, hopefully someone here can tell me. friends have said to replace with pineapples. but still no one has said they have anything in the bushes area so why would it leak ??
cheers
AndreW
Edited by AndreW_R32
https://www.sau.com.au/forums/topic/369052-r32-rear-sub-frame-leaking/
The bushes are oil filled. They have cracked and are leakibg.
Couple of options
1- remove subframe and press in new bushes or pinapples.
2- lower subframe and put in subframe c lock spacers. This removes the slop that the worn stock bushes have. But also create some NVH.
Mine were leaking too. Seeing as I track my 32 occasionally I decided to put the C locking rings in mine. TBH I haven't checked if it still leaks LOL but it definitely stiffended it up in the mean time.
I'll probably look at replacing them one day.
