After blowing the engine of the R35 into 4,823,163 pieces (Yes I counted) I decided to get my local mechanic to fit the engine rather than doing the sensible thing and send it to Martin at Willal.
WELL on opening up the lines etc there are pieces of engine in the oil cooler, in the filter in all the oil lines we even found a gudgeon pin in the throttle body.
We are going to flush everything out but how can we be sure that there is no shrapnel left in the circulatory system of the car.
https://www.sau.com.au/forums/topic/369242-r35-engine-replacement-problem/
:O
There's probably no easy way to do that, other than manually disassembling all connections and peering into / flushing them. Assuming fluid can sufficiently pass through the circulatory systems when you flush them, they should be safe. Worst case scenario something dislodges down the track and blocks up the works, but shouldn't cause instantaneous catastrophic damage unlike things trapped in the intake.
The intake and breather side of things is, at the least, what I'd be pulling apart piece by piece and either replacing or making sure they are free of shrapnel. Anything that can make its way into the throttle body etc.
Metal detector / stud finder might be of use?
replace the oil cooler cores. too many fine passages in there and just too big a risk to flush and hope for the best after a catastrophic blow up. remove and flush all the oil system lines and even the cooling system (un-usual for stuff to get into the coolant circuit though). as far as inlet goes I'm sure head has been replaced/rebuilt so just need to remove the inlet and exhaust manifolds and clean them out properly.
I guess I'll be the first to ask....
how did it happen?
F....d if I know!
Just driving through turn 9 (The one after Corporate Hill) at Eastern Creek when I heard a huge bang.
I thought it was a tyre blow out until the car came to a slow halt leaving bits and pieces of car across 800 metres of track
If you are concerned even after flushing and pulling stuff apart consider mesh filters in various supply lines to the engine (coolant/oil etc etc) after putting back together. Similar to the ones used in dry sump setups.
F....d if I know!
warranty? or was it mod'd?
SURE = 100%. You cannot be sure. Apart from replacing the entire system.
But you can be reasonably sure. Flush lines and components with solvents, look at the outflow.
Throw stuff that has small gaps (e.g. oil coolers), hope for the best.
Cheers,
SW
  • 4 weeks later...
  • 5 months later...
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
