I went and had my first look at a C34s2 Stagea today! This one actually
I loved the car except for one thing... I'm not sure if there is adequate driver's leg room. I'm 6'6", so this is a pretty serious consideration for me when shopping for a car (and other things).
Is it possible to modify the seat rail to help alleviate this problem? If so, are there any recommnded places in Adelaide where I could get this done and complied?
Hopefully this won't be a barrier to me getting in a Stag... I don't want to have to get a Commodore :(
https://www.sau.com.au/forums/topic/369399-drivers-leg-room/
Im 6'8" tall.
I run a Bride Low drivers seat rail on a Saas D1 seat
Used to have standard chair but modified the rail to go back an extra inch.
The Bride Low rail helps the seat go riiiiight back, legroom therefore not being an issue whatsoever.
edit: modified the rail in the shed, so not exactly legal although was sturdy enough. Wiltshire motor trimmers, South Rd, would be able to do it legally I believe. But for the cost I feel you'd be better off taking out the chair/rail and use a bride rail with chair of your choice.
Im 6'8" tall.
Ah now that's what I want to hear! If I wanted to save some $$$ would I be able to use the bride rail with the standard chair? Where did you get your rail/chair?
you'd need a sidemount rail to suit the stock chair, going by memory.
I had a friend pull apart the standard rail, make some new holes in the rail to enable it to slide back further (around 3cm extra leg room), and re-weld back together
I ran that for 3.5 years until got fed up with the stock chairs' lack of lateral grip.
Bought a bride rail from ebay, a $299 Saas D1 drift chair from autobarn, removed the standard chair (eventualy threw it out!) and simply bolted in the aftermarket chair with rail.... soooooo much comfier and probably 2 inches extra leg room all up. Ive had this setup for over 2.5yrs now, very happy with it. Just decreases legroom behind the driver, makes the car moreoff a 3-4 seater as such; definately no adults behind me due to no leg room for them, its all miiiiine!!!
Trust me, with legroom being a HUGE issue for me. 201cm tall and have had BOTH kneecaps (patellas) removed and not replaced.
Being comfortable is my no.1 aim in life, so to be comfy whilst driving is very important; hence in the end the decision to replace the stock seat (I have tracked the stagea numerous times, and am a Hills driver - used to be a Hills bike rider for a decade......)
A bride rail will also give you more headroom as the seat will sit lower and further back for the go-go-gadget long legs.
Update: So I emailed Willshire Motor Trimmers, asking about modifying the standard seat rail, here was the response:
Unfortunately extending the rails to get you some more leg room isn't as easy
as it sounds, especially with the Nissan style of slides. This is due to the
slides being an integral part of the seat frame and seatbelt buckle attachment
on your left side.
Another option may be to fit an aftermarket seat such as a Recaro, that way we
can manufacture the base frame in such a way to give you some extra
room.
About 40mm or so extra is normal.
They don't seem all that willing to do the job...
Can anyone tell me more about the sidemount rail to suit the stock chair? As in, model number, price, where to get it from etc.
I can understand why; it will always be a compromise; modifying an OEM rail. Having said that; I've done it stacks of times (just not engineered) and they have been just as strong as OEM.
Going back further is not very hard at all, but going lower using the OEM rails & seat will take some creativity, and it's likely to end up costing more than just buying a proper rail.
I'd approach an engineering workshop personally; you're likely to find someone who'll look at the problem more laterally.
Link to rails; http://www.nengun.co...g:1;c:119;t:n:u I've used Nengun several times before and they're great; shipping can be a little slow, but anything good is worth waiting for.
Hope this helps.
Edited by Daleo
Thanks guys, I appreciate the replies. I think my first step will be to approach the engineer's workshop personally - they've replied to my follow up email suggesting that.
If they can't help me or the cost isn't going to be worth it, I'll look at these other suggestions.
I'm 5'11" and I hit my head on the roof lining with a hat on (in my s2 (w_ sunroofs))... How do you guys at 6'6"/8" do it??? even with modifed seats for extra length. What are you.. lying down??
There is heaps of room under the seats ( I have amp's under mine), so getting a smaller base seat to sit down more shouldn't be too hard.
As sugested above, give a set of GTR seats a go.. goood support, sit low, oem quatity and are cheeap.
:cheers:
:cheers:
how big is your hat???
i'm 6'2 and my head is nowhere near the roof!
maybe you your seat adjusted up way too high
  • 1 year later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
