Guest INASNT
Going by the theme of the other recent threads maybe rename this thread to
"Very Special Wing"
Dont forget to add it will give you so much more downforce that u will run atleast 1 sec quicker in the 1/4, and its liquid cooled so it helps the air at the back stay cool so it give u more downforce :rofl:
I'm so over people doing stupid shit to cars... it's not funny anymore.
We've got the:
"Uber-wing" car above,
The "Star Wars" Honda CRX,
The "Town Map" 180SX,
The Merc/BMW/POS matt black Honda CRX from Gayville, USA
The 30" Chromies Buicks
Fast and Furious Rice
etc,
etc,
etc...
Oddly enough, most of it is coming out of the US.
"Very Special Wing"
INASNT has a new NEMESIS
what do you mean ....... they invented BLING BLING .... I am only suprised it has not got spining wheels ,
