Hi guys,
Got a few questions to ask and hopefully anyone of you can give me an answer/solution...
1. Last Tuesday night I was driving in Melbourne's unusual fog, got my cruise control on and turned on the front windshield heater...suddenly the cruise control just turns off and didn't register anything...the radar symbol is still on but not showing any cruising speed and I noticed that the cruise control is just off...this happens until I turned the car off then turned it on again, tried the cruise control and it's working as normal, tried turning on the windshield heater and it's gone off again until i restart the car...any ideas why? (sorry if too long, can't think of writing the short version without really confusing anyone)
2. I had the O2 sensor busted and am still waiting for the sensor to be ordered & delivered to the workshop that I frequent. The boss had a look underneath my car and said that it looks like my turbo is starting to leak. Called the previous owner to ask and he said he didn't have any issues and the turbo was just fitted not too long ago...any idea on why?
3. I will need to do servicing in the next month or two...now I need some help on part numbers for oil filter, type of oil that you guys recommend (what viscosity too) and part numbers or equivalent parts for the front and rear disk brakes and pads (fronts are the same with which car and same with the rears)...
4. My car came with the Bose sound system...just noticed that the FM range just went up to 90MHz...is that normal because the car is from Japan?
5. Is it possible to burn an Australian navigation map/system into a DVD and pop it into the dvd sat nav drive? does it work?
Sorry for all the noob questions...still learning a lot on my car...
Cheers,
-syd-
https://www.sau.com.au/forums/topic/369568-questions-on-m35/
  • Replies 193
Posted Images
Syd, first thing I recommend... Is SEARCH!!
Question 3 still has an active thread from within the last week. Opinions vary, check the thread "m35 oil and filter"
4. Yes it is normal. Dunno if they fitted band expander but my understanding is even so it'll show 90MHz.
5. No. No way of getting sat nav working, but you can get it translated. Look at www.xanavi.com.au to find your local person.
This could be a "feature" in that some engineer thought it could be too dangerous to run cruise control in conditions that warranted you having the windshield heater turned on, ie. icy conditions.
Sounds like you have the cold pack edition.
2. Might want to have a look under the bonnet and see if the oil leak is coming from the passenger rocker cover (it will drip down onto the turbo). This is quite common.
3. http://m35stagea.info/forum/viewtopic.php?f=6&t=63 and yes as Ryan said, check the Oil Filter thread :)
5. No chance for sat nav. It has been covered here so have a search for the thread
3. http://m35stagea.inf...ic.php?f=6&t=63 and yes as Ryan said, check the Oil Filter thread :)
any long term issues or solution on how to fix this? after a drive i smell something like oil burning...
i have registered into that forum but i still can't access the site...
Have you changed the oil since purchase? If not, I'd do that ASAP and use a GOOD quality oil (do a search it has been covered ;)).
Depends on the leak, but mine has had a very small leak for years now with no troubles.
Solution is generally to replace the rocker cover seal.
(airbox out, rubber bend and AFM off, plenum off, unscrew rocker cover bolts, replace rubber seal, re-install rocker cover etc) - fiddly job though due to piping at the rear of the engine)
Iain, looks like you need to fix the site again.
thanks for the advice, will do that in the very near future as I currently have other issues that's more urgent than the car...
I checked the site again and tried to log in, apparently my username is still not active and I didn't get any email asking me to activate my login...
Send Iain (zei20l on here) a PM, I'm sure he can fix up your login.
got a wheel alignment done today...the guy told me the sound that I thought was from tyres out of alignment was in fact the front right wheel bearing...does anyone know the part number for wheel bearing or if M35 wheel bearing is the same with any other nissan?
any help would be appreciated as i plan to get this sorted ASAP...
need more help urgently guys, any fast response is greatly appreciated :)
my car currently has a busted O2 sensor so its fuel efficiency is about the same as an F1 car (well not exactly but u guys know what i mean)...is the O2 sensor for vq25det the same as any other vq engine? and how do i know which O2 sensor (primary or secondary) that would need replacing?
How bad is your fuel efficiency? My city driving gets me north of 16L/100km; never above 21 though; somewhere in that band isnt necessarily pointing to your O2 sensor.
There is only 1 O2 sensor in our cars, its in the exhaust dump just behind the turbo. The part number is 22690−AL600
thanks dunc...maybe i'm just still used to hondas which used different O2 sensors (i remember euro had 2)...
i think my car's fuel efficiency is pretty bad, as in maybe about 350-400kms with about 3/4 tank (i use cruise control mainly for driving), my driving is 50% 80kph, 35% 70kph, 10% 60kph & 5% 100kph roads...
Edited by Sydsyd
Drive it till the light comes on, and fill up completely - that way you can at least get a decent read on what your L/100km is and make a decision from there.
well the ECL is on all times, tried resetting like 3-5 times, every 2nd drive after that the light comes on...checked all the codes, all pointing to O2 sensor...so have to replace it anyways :(
i'll find out the fuel efficiency soon before and after putting on the new O2 sensor
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
