I like shell helix as a cheaper oil, or even some of the valvoline stuff is quite cheap and goes at a good price.
what do you guys think of penrite and castrol?
I work at Repco and Barbagallo raceway on the weekends, I've only ever heard bad things about castrol and valvoline oils, and most of our trade customers swear by Penrite oils. after what i've heard i'll never again put castrol oils through my engine...
I use penrite SIN range on my car too.
At barbagallo I only ever seem to see empty Motul or Penrite bottles...
All that said, i'm still yet to see a convincing piece of real world evidence that one oil is better than others, just stories from mates of mates etc...
https://www.sau.com.au/forums/topic/369569-what-oil/page/2/#findComment-5902340
https://www.sau.com.au/forums/topic/369569-what-oil/page/2/#findComment-5902343
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
