Hey
Thinking about up grading the front brakes on our M35(when it arrives) to R34 GTT.
I looked in the brake thread but it's all over the place.
So can anyone confirm if the GTT discs and calipers will bolt straight on? I understand the brake line might need some work but that's easy to take care of.
Cheers guys.
Cool. So the r34 gtt caliper uses a larger mounting bolt than r33. I'm assuming the M35 also uses the larger mounting bolt or am I wrong?
If this is correct I shoulnt need the bolt sleeves.
34 GTR front Brembos are definitely 324mm, I will have matching sized disks as the Z33 rear Brembos are 324mm also. (Same as the later BNR34 rears.)
I got the Brembo disks machined yesterday, he had issues cutting them they were so hardened. Grade 8 he said. They required a carbide cutter to face, not bad. :cheers:
296 = R33 GTST and R32 gtr except 2mm thicker.
310 = R34 GTT
324? = R33/34 GTR
this is correct
non brembo r32 gtr is 296x32mm, r33 gts-25t is 296x30
r34 gtt is 310mmx30 and r34 gtr is 324mm (i forget what thickness)
everything r32 and r33 has 12mm bolts up front, r34 gtt and gtr brakes have 14mm bolts up front
on a side note, the 2 pot rears are the same from r32 to r34 :)
i thought 350z calipers etc was the M35 upgrade?
its the better option because you get 324mm rotors if you get the brembos
but brembos always carry a premium price
i thought the rotor hat height was the main difference between R33/34 and 350Z? being that the R34GTR brembos have a height of 53.8mm and 350z brembos a height of 49mm. clearly if you match the caliper to the rotor you should be right but depends on the hubs being the same. so if you fitt R34 brakes to your M35 they will sit in further than standard (better caliper clearance?)
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
