hey guys just a quick question
my car has a hks ssqv on it but i hated the sound it makes
so basically i dodged it up with a mountain dew can so it is blocked and not working
can u still get defected for this even though it isnt working
cheers in advance
https://www.sau.com.au/forums/topic/369742-bov-defect-question/
Best bet mate, if you dont have the standard one still they are cheap as shit for the to buy. No doubt they see one of those shiny looking ssqv bov's on there it will be sticker time for you. Plus like you said, they sound shit.
Edited by cannabiscorpse
yeah still got the stocka
i know wat is the deal with that worst sound ever
im enjoyin dosin everuwhere i go i mite just put stock
one in and block it wit my mad moutain dew can modification
LSHMSFOAIDMT
yeah cars only runnin stock boost n stock turbz so im not worried ill
leave it blocked
Yeah man, i havent done it cause im not big on the sound, but i read a huge thread on it and it seems there is no solid info on it being unhealthy for the turbo. There was a few guys pointing out that its bad for the turbo etc, but all the guys that had done it had zero problems.
it's not an immediate issue with blocking off the bov, but it will shorten the life of your turbo, plus the fact that it increases the response time. my old 180sx had the stock bov on it and they are crap and do bugger all. i put an aftermarket bov on and it felt like a totally difference car on gear changes. so much less lag.
you have to remember that by blocking off the bov you are making all the air in the cooler piping go backwards out of the turbo (and AFM). this means the turbo is slowing down dramatically, and the ecu is pumping extra fuel into the engine, so you increase your chances of it stalling when pulling up to an intersection as well as fouling the plugs.
Well its a very individual taste i guess. Not something im into, even the standard bov gets annoying with a pod filter occasionally. I did read on the thread i was talking about that it was commonly asked by tuners to remove the blocking piece. Imo thats a good enough reason not to block it off, but as you said- each to their own.
Yeah but a stock rb25 turbo is nylon/ceramic and journal bearing
An s15 with steelwheeled ball bearing turbo will last alot longer with no bov than your turbo seriously don't block the bov
The s14 I bought recently has no bov I'm totally sick of the sound after 6 weeks and I'm trying to raise the funds to get a bov so I can stop my car sounding like a pigeon
His car, his choice mate. No skin off your back if he stalls it or has to replace his plugs everytime he fills up. The others have pointed out the negatives, and if he wants to risk it, so be it. Having said that, most blokes dont have a problem. One person has said he had to raise his idle to compensate.
For the op, this is thread i was talking about. At the end of the day its up to you and your personal preference, As the others have said, its not as ideal or efficient, but you know that.
http://www.skylinesaustralia.com/forums/topic/240998-blocking-off-bov/
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
