So i want to cut my reo bar and heard it was illegal!
is this true ? and if so how likely that i would get defected for it... oh and is it heaps more dangerous without it ?!?!
If you see attatched photo youll understand why i want to. I have a moustache
https://www.sau.com.au/forums/topic/369991-want-to-cut-reo/
Its illegal to cut or grind the steel reo bar that supports the front panels.
I don't think your moustache [if its the bit holding your number plate on?] is the reo bar prob just FRP or plastic, but why don't you just paint that bit black? The reo bar usually sits a bit higher than that, its above your blinkers. If your on P's then your car is not a turbo so it won't have a FMIC so there is no need to cut or mod anything.
Usually you have to mod the reo bar to get a fatter FMIC in behind it. You shave off approx 5 mm from the underside lip but the top lip is usually never touched.
https://www.sau.com.au/forums/topic/369991-want-to-cut-reo/#findComment-5897409
It's not only illegal, your insurance company will wipe you.
How many people are there, though, that run an FMIC without cutting the reo? They just don't fit unless you remove your AC parts to fit the cooler more frontwards. My old car had a very hacked up reo, insurance didn't really look at it either when the car was written off.
https://www.sau.com.au/forums/topic/369991-want-to-cut-reo/#findComment-5900315
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
