  • Replies 58
The hybrid turbo built by Matt and others cost around $400 I thought (mainly for machining - use an standard R33 Turbo; the exhaust housing of a VG30BB turbo, and a T04 compressor wheel).
This is a budget upgrade as good or better than some of the $2000 hyflow options.
Enrico,
I've also noticed stocker RB25's holding together with bigger injectors at higher power levels.
When an injector is pushed to its limits the spray pattern is affected. Not all injectors may be affected it may only be one that starts stuffing up and may not stuff up straight away either.
This will hardly show up on AFR's as the AFR's are averaged out over the 6 pots.
Without good fuel atomisation you get a crappy burn/lean out hence why possibly detonation occurs which sends combustion temperatures through the roof eventually smashing ring lands. This is also why sequential injecton makes more power over batch injection, better fuel atomosation = better fuel economy & power.
I think.. :(
Enrico,
I think.. :(
I'm with you Joel.
Some other ideas:
Maybe the pulsing of the injector starts to get chaotic at say greater than 90% duty cycle, or at even lower duty cycle but when it has high fuel pressures and you get insufficient fuel when under high load for longish periods like when winding up to 180km/h in fourth.
Maybe by raising fuel pressure (via Malpassi reg for eg) you also reduce flow to injectors as higher pressure for the same given fuel supply = less flow according to flow dynamics I think. But some people say that with big fuel pump like Bosch 044, the fuel supply presssure and flow is so huge it should be OK.
Maybe by using a reg to give you high pressure you also cause differential pressure drop across rail from one side to the other or within the rail and say cyl 1 or 6 gets less fuel than others but as Joel said it won't show up in average A/F ratio out the tail pipe.
With big injectors, you get high flow at low pressure which I think is better and it gives the right spray pattern and even fuel supply across rail.
BTW RBVS, Joel also might know more about rebuild options as he's doing one now for RB30.
I think of it as an injector having an efficiency range + or -.
When you get out of the efficiency range it simply starts dumping the fuel in not spraying it.
Hence why SK states the RB injectors don't have trouble with was it +15% extra fuel pressure?!?! I can't rememeber. He's said or typed :( it a few times now.
+ the fact of if the injector is running a high duty cycle it is obviously going to valve bounce if you like (Tims words).
yea i was thinking about what you said with cars with stock injectors dont seem to last. Also i think it is the spray pattern not covering evenly , hence other spots on the pistons not being cooled.
freebaggin: i have been looking into the rb30 bottom, just have to check iv got room to move 30mm up.
yea if anyone can give a price or advice for building a 25 or 30 bottom end would be help full, just the build as im going to try slapping the head back on and dropping it back in to keep cost down.
Dean, might I suggest saving for upgraded injectors and not trying to push the stockies to mid/high 200rwkw levels! Take it from me mate, an extra 1k or so (for 550's) now is better than replacing a piston or two down the track.
Do a search and see how many RB25DET rebuilds have occured with stock injector, bigger turbo, GTS25t's. I got away with it for a while. I "may" have got away with it for longer with a very conservative tune? I use to post on here supporting the 044, reg and higher f/press combo. Not anymore!
Of course if you'd like to go the whole hog, do forgies, lower the comp ratio and go for big boost... then go for it mate! It's heaps of fun :D
yeh matty, ive had a big think about it, and everytime a rb25 ringland goes, everyone blames it on the tune. only recently did u guys think it could have somethin to do with pushin the stockie injectors too far. this could definately have adverse effects on spray pattern.
u had stock inj when engine went
boostd was the same.
there are probably many more cases.
needless to say, i think once my car is retuned, ill keep it like that for a while then think about a bigger turbo.
cyas
G'day gobiz, my turbo is a bit of a bitza. Sorry I can't give you any hard and fast data on it :D
Here's what I do know:
It's a plain bearing Garrett based T3/T4 with a T04E 0.60 comp housing and a 0.64 exhaust housing. The exh wheel is quite large and it's been backcut. The exh housing has been machined out to fit. It has what those in the know stated as a very big comp wheel squeezed into the T04E housing.
On my engine the turbo has damn near the same response as a HKS GT2835ProS. With a touch more power and a quite a bit more peak torque (similar boost). Same dyno same day.
whatsisname, this turbo wouldnt be suitable for rb20 would it? i dont care if boost doesnt come on till 3500-4000 at the moment. mite be swapping till rb25 in the future. is the exhaust housing similar to vl turbo? or just a .64 sized t3 off the shelf item? what boost are your running?
Matty, is your turbo the same as Boostd's (Mat's). If I recall the specs on his were as follows:
used an standard R33 Turbo; the exhaust housing of a VG30 BB, and a T04 compressor wheel. Vtrim Comp with groove in comp cover snout. Exhaust bored out to flange.
machined at Russel Engineering.
If not, bo you have any info on how your turbo compared with Mats
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
