Hi all,
I have a one-month window coming up in a few days during which time I plan on getting my engine rebuilt properly. I am desperately seeking a set of ARIAS RB25DET *NEO* forged pistons; these must be a copy of the OEM piston, not an off-the-shelf variety (these are all for '33).
I am aware of a set of CP NEO pistons being sold on here however they are 86.5mm (first oversize) which my block already is, so I would need a new block to use those.
I have contacted SPOOL imports but the guys is on annual leave. Ordering through an Australian supplier who doesn't have any in stock will incur the 4-6 week wait while they are made in and delivered from ARIAS' facility in the US.
Anyone know where I can get a set at short notice? Yes I've tried ebay...
cheers
DaveB
if you honestly need them just do a google search and ring/email every single shop you find.
this is what i would do, even email ARIAS direct? might find they have a set there/ or being made as we speak
air express ahould only take 5-7days max?
I will try; the engine builder I consulted says that these are a custom order and that ARIAS do not have any stock. Which is the same story I seem to be getting from the other retailers...
Edited by DaveB
ohh bummer then
i guess asking arias yourself could be the only answer to see if there available or not.
not looking at other brands?
ohh bummer then
Yes looking at other brands... only other ones I've heard of are Wiseco and CP; CP are apparently OK but I haven't asked the builder about Wiseco. I wouldn't even know where to get these from as I don't know if they have the custom measurements on file for RB25 NEO.
Pistons can be organized VERY quickly.
Ring up Quantum Racing in Brisbane, they're the CP importers, give them the specs and tell them its a rush order and you need them as fast as humanly possible.
With custom pistons they can be done very quickly, the price goes up by a percentage based on how rushed they are. With JE from memory its 50% surcharge for a 48hour turnaround, then express air mail which takes about a week door to door.
Expect to spend more than $900, but you will get them done in time.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
