You can't mess with the knock sensors very easily. They are really just piezo microphones. They listen and feed the waveform back to the knock board in the ECU which decides if it's hearing knock or not. If you wanted to fake a knock sense, then you'd need to send a convincing waveform that you'd have to synthesize somehow.
From my experience with the knock sensors and the knock map, the whole thing is not reliable anyway. I couldn't get my ECU to stay on the main map even though it wasn't pinging, so we just did what a lot of Nistuners do, which is to make both maps the same. That way you don't find yourself drivign around on a soft map, and the extra safety actor can go to hell. My ECU has been tuned like that for a few years now, and there has not been a single moment where it has been bad.
  • Replies 59
That was me with the CarPC and switching maps and PULP98 and E-Flex and all that...
After running between the 2 different fuels for a while now, I've found it a bit of a waste of time...
As in i wanted to get around the "draining the tank and then switching fuels" But I end up just loading the PULP98 map and trimming the AFR's to suit for the couple of "Inbetween tanks" where the mix is somewhere in the middle of E70 and E0.
But having 2, 3, 4, as many maps as you'd like is easy with NIStune.
As for the capacity of power limits ect. forget about it...
Just make a headphone jack for the knock loom and plug it into some really bad metal, lol.
If ever there was a bad way to achieve something - you guys have found it
Buy an ECU that gives you all the functions you want. If you really wanted to do double maps, you can do what some of the Jap companies were doing and doing a double EPROM with a switch on pin 1 for power or whatever it was. It just swapped power to the other EPROM and ran a seperate map.
Doing it with knock sensors is kinda dodgey and pretty funny at the same time.
I don't think anyone was actually going to bother heh.
In the $2k range what ECU would you recommend? The V500 still?
Yeah the V500 is actually more advanced than the Motec at this point. Runs 6 multi controllers and is the only ECU other than Motec that does.
You need to read up on this ECU to fully understand what it is capable of. You can overlay each map over each other and each multi controller has 6 inputs and outputs or something like that. Each one can be made as a 32x32 table which can be layed over any other table.
So you can do boost over wheel speed over tps over fuel pressure over nitrous pressure over ignition timing if you want
Pretty much whatever you can imagine.
Only after swapping to the V500 did all our problems go away.
As far as I know it's really good. I am not a tuner, just an end user. From what I have seen though, it is very 'thorough'. I don't think it's something just anybody can get a handle of. You need to know what you are doing. I have heard people complain about the current software but it's always stuff that exceeds their knowledge so they are only complaining in ignorance
V500 is junk... cannot be compared to a $1400 LINK G4 or Vipec or haltech for that matter... worlds apart in quality.
This is pretty much what my mates tell me, but I always hear conflicting reports on here, though I get the feeling the people who say it is good don't actually use it.
Heard much about the DTAFast range of ECUs?
Edited by Rolls
Lol @ using a vibrator to set the knock sensor off.
Im not 100% sure but if the knock sensor is faulty it will run on the knock maps. I havent checked the resistance on a faulty sensor but i know a good sensor is 570kohm.
So if it was as simple as setting a 2nd wiring circuit with a higher/lower resistor so when u switch to the 2nd circuit it jumps to the knock maps.
I dont trust the knock maps. Especially at higher rpm where there is alot of valve train noise
I thought it was an AWSOME idea... ha ha ha. it's right up there with the clasics- trim pot on the afm, welding the clutchplate to the flywheel, skipping a tooth on the cam gear/belt on a vl rb30, stick on wrx bonnet scoops and plastic spinners rims.
J.
LOL
only thing i dont like about my NIStune is it doesnt show knock readings for the r32 gtr, but apparently Matt has been trying to make it work for years now...
You can get real knock (audible on knock ears) but have it not register on the knock count, I wouldn't trust the standard nissan system.
Non of them accurately show knock reading like power fc does michael.
The ecu has an internal knock board that senses knock which then switches to the knock maps. But doesnt let the user know when it does it.
would you prefer that the ecu shows you that its knowing and flashes a light at you yet does nothing about it and by then it may be too late (power fc) or would prefer an ecu that when it senses knocking reverts to a knock copy map which saves the engine. (nistune)
The issue is it doesn't half the time. We put a set of knock ears on my old car and reved out 3rd gear on a hot day (30c) after idlding it around for 30 minutes to get it real hot and it started pinging its tits off, didn't go to the knock map where we had taken 5degrees out across the whole boost section.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
