Yeah you can roll a bogged guard...gotta be very careful that's all, and be prepared to touch up. Paint can crack anyway without bog there. If guard roller is good it'll only crack in the part that gets rolled and then you can't really see it.
Mine needed rolling front and rear FYI
But I'm running 265's on the back and 235's on the front.
They were only just rubbing, rears rubbed when going over harsh bumps and fronts rubbed when turning
thats supposedly 2 degrees of rear camber (According to pedders) looks like more but
Edited by 89CAL
  • 2 months later...
sorry to bring this thread back up, how will 17x8+33 and 17x9+37 look guys? i just want something to sit good without needing spacers, i am also going to have camber arms on the rear and if anything ill get the front rolled
these are the specs they have in stock as im most likely going through this dealership, its giving me a headache trying to work out what to get :wacko: i just dont want something to sit inside my guards to much
The 17” D1R’s come in an 8, 9, 10 option.
17 x 8 is in an +33 offset.
17 x 9 comes in +37, +17 and -4.
17 x 10 comes in a +15.
The matt black in 17 x 9 +17 and 17 x 10 +15.
See my previous post for side pic. it needed the guards rolled but thats all, no camber arms.
oh yeahh i see i might get 17x9+17 all round then. all would the same size all round look shit?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
