Never heard of out, Forced performance do their own hta turbo with a similar name though which I don't know of anyone using on an rb but I recon it would be a good high power combo. I know someone with a 3586hta on an rb30 and it makes over 500kw on e30 with awesome delivery.
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-5917341
http://www.skylinesaustralia.com/forums/topic/251820-got-over-400kw-atw/page__hl__over+400kw__st__900
In this thread you will find results from 3788's, try to remember they are bolted onto big budget RB30DET's and not your average forged motor.
Considering there are 4088s and 4094s I have no doubt that garrett has simply mixed and matched some existing parts. IMHO I would expect the 3794 to be a little better under the pedal and make roughly the same power as the 4088. With the 3788 still being the pick of the bunch.
In the GTX thread I already told you to search and that if someone had one it would already be posted. Moving on..
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-5917415
They actually seem to push more than 4088rs in the cases I have seen, interestingly enough.
Yeah, power capability of approx the 4294 but the response of something like a T04Z
Only a turbo you would select for making easy 600hp at the wheels or pushed hard to 800hp at the wheels with the right fuel.
We use the 3788 as it's better suited to what we do/need
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-5917518
  • 9 months later...
For anyone that is interested, these seem to get less attention than the PT67 turbos but I've been a little more fascinated by these.... haven't said too much as I've been keeping an eye out for results on these things for AGES which are closer to indicating what to expect for those of us who don't want to have to rely on E85/huge boost for making good power and good spool - found that someone has run one on an XR6T and made really good power relative to boost level on one, despite being on a fairly basic setup with stock manifold etc. 400kw on 1bar on pump gas, for example... and sounds and spools awesome!
So now I'm pretty much convinced this would be a gun turbo for a big power RB that retains some form of streetability, they've made >900hp @ wheels on E85 (American dyno style, but still equates to >600kw @ wheels Dyno Dynamics if you take in account the differences) and pushed various Mitsis into the 8s.
See here:
And thread: http://www.fordxr6turbo.com/forum/topic/78068-boosted-1-in-with-446rwkw/page__p__1166770#entry1166770
Need to somehow fast track finding money to build an RB30DET suitable for such a setup :)
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6320960
  • 1 month later...
So, a 2litre EVO in the USA just put down 570awhp/425awkw on pump gas using a FP GT3794HTA (they did the 1.2 correction trick a lot of UK workshops do to estimate Dynojet/BHP type figures to get 684hp) - pretty impressive result all the same!
Mods:
· FF Shearer HTA3794 kit
· Magnus Intake w/ 65mm TB
· Buschur twin fuel pumps, ID2000 injectors
· Ported head, stock size valves and Kelford 280 cams
· 2.0 Liter Built
· Sparktech Pro CDI
· AEM EMS
Dyno plot:
Thread: http://forums.evolutionm.net/evo-dyno-tuning-results/616277-shop-fps-hta3794-combine-another-killer-pump-gas-combo.html
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6406068
So its 580rwhp with god knows what air temp, ramp rate or boost.
Cant be compared to anything....... Weigh the car..... run it down the strip.
If its 3000lbs and does 140+ then its about right.
Yeah im always suspect of DD graphs without te most important data visible. In fact we just did a test on a Mainline 4wd Dyno (new) and found quite a few variances in power outputs by changing very little 160rwkw first run r configure then run 200rwkw just by a few keystrokes...just to easy to fudge figures. Need to have the full story with dyno sheets.
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6407293
Fair enough, I'll keep the thread up to date with anymore info - its in the US and most people don't trust DD anyway so he is going to re-run it on a Dynojet. They sound like they expect it to do >140mph traps.
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6407476
^ yep, that and its running on a 2litre engine - life needs to make as easy as possible to make that kind of power.
Black bnr32, I'd love to see some dyno plots of EVOs making 420+awkw on a Dyno Dynamics dyno running straight 98 using a GT3582R.
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6407528
I always used to love DD because I think they give more realistic figures compared to hubbers, but after using the dynapac lots now I'm converted. The ability to have such repeatable and consistent results so you can actually compare cars and/or modification effects is awesome
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6407882
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
