Hey
I want to remove this thing but I don't know how.
I don't even know what its called.. "Car Window Shading Ugly Brown Stuff"
It seems to be taped down with double sided tape. Not sure tho, if I try to pull it, the tape thing kind of stretches and looks sticky.
How do I properly remove it? Is there like products to remove it? What do I do? It's so brown and I hate it lol
Also there are some metal clip things hooking onto the black rubber thing attached to the car: shown in the pics..
I think they are called wind deflectors, that's what I call them anyway. Get a bit of packing tape to cut through the double sided tape. Looking at your pictures it hard to tell how the metal clips are holding to the deflector but the metal clips should just be sitting under the door rubber seal. If there is any tape left on the car get some prepsol and plastic pry tool or even use your fingers. Just squirt some prepsol on the tape hold a rag underneath to catch all the excess prepsol and let it sit or a minute or 2 and repeat a few times. After a few squirts of prepsol use a plastic pry tool or you finger to remove the tape. Might take a few goes to remove it all.
Deller,
It's just that I took up a new goal for my car to be black and not having any parts being a different colour, with the exception of white, and not brown.
Like just recently I've ordered smoked white indicator lights with orange bulbs to replace the current orange ones and also painted my wheels black.
So yeah.. anyways..
thanks olloSKYLINEollo
I'd rather remove it for a better look.
It didn't bother me much until I kept seeing other R34's without it.
It just bottled up inside and only just recently I'm like " Thats it, its coming off! "
Then why don't you just paint them black?....
Mine are turning purple/brown.
Would you recommend just painting them black (non see through) or with those black (smoked) lens paints?
I personally would recommend CF wrapping it haha.
But to your question, I reckon smoked is cool
Haha thanks :P
Nah it's not that expensive, not too hard either.
Here's a link to my thread for you :)
http://www.skylinesaustralia.com/forums/topic/296681-carbon-fibre-vinyl-wrap/
  • 3 weeks later...
RIght.....
I am in the process of starting up a thread with all the stuff iv done to my car in the past.
One of the things I did do was paint these "window wind protector things".....I painted them with a plastic primer and then gloss black paint....
They match my car...and look awesome....
They are also quite handy...they keep the wind off your face (if you drive with your window open) and more importantly..they keep the water droplets off...
Like when you wash your windscreen and all the annoying water bits spray on you...it helps..trust me
Also they act as a good sunshade...
Why remove them..when you can paint them....and / or wrap them in carbon fibre etc..
I would rather you just paint them..but then again..thats just me
Cheers
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
