Just got my car back with the side skirts fitted but unpainted. Sounds like it is going back to them tomorrow.
I didn't want to leave my car there because the panel shop would of had to park her on the street over night - So I felt much more comfortable knowing I could have her in my garage safe and secure.
The drive home was horrible knowing I have these 2 big white chunks on the side of my car (My car is dark blue).
I feel like the biggest cop bait in town.
I also felt I should share my pain with everyone :(
https://www.sau.com.au/forums/topic/371674-my-unpainted-body-kit-sad/
don't worry I know how you feel. My friend said he will paint my front bumper and side skirts for me for free i just had to buy paint. Now he has finished it and fitted it. My car is pearl white and the layer of pearl he put on was almost like nothing so part of my car looks white and part of it looks pearl. Need to save up some cash and take it to panel beater and get it done again.
I feel you pain buddy, I had an unpainted BN front bar on my car for almost a year as I destroyed my last front bar and had my full Do-Luck on order (Took 8 months to get a copy). I felt like scum taking my car out with a front bar in primer but the car is at the body shop now so once I get the car back I should be back to the one colour again.
I feel your pain. I had a small paint blemish about the size of a pin head on the underside of the drivers side rear pod. If you got down on your knees you could just see it.
I felt terrible driving around with it there. :whistling:
Shoulda just spent $50 on a can of spray paint and did a home job for the time being :P
I didn't end up returning to the body shop to finish the job. Decided to give it a go myself.
lol - I'm going to end up painting mine on Sunday. Prepping tonight.
Meeting up with sonnyQ tomorrow for tinting - And yes, with unpainted skirts! /cries
Well I did manage to get the car back today. if I have time i might see how I go fitting up those DIY lips from Charles. I might try the carbon wrap on them to. No way in hell I could have done that good a job for $900. They also gave me some paint in a small container for any touchups I need to do and they also went and did the major touch ups for me.
im happy with the result, $900 was for fitting and painting the front and rear bar, re-allignment of my doors (they started to sag), painting some after market mirrors (not on the car atm), touching up the side skirts and they also did a few little touch ups here and there. They even provided me with a small tub of paint incase there was some extra touch-ups i wanted to do myself. They use a camera system to colour match where they take a photo of the paint and tells them what its made up of or something, the guy was telling me about but had to leave in a hurry because there was another guy trying to get out around my car and I didn't trust his driving.
Kit is painted - Did a home job, but quite happy with the result :)
http://www.skylinesaustralia.com/forums/topic/371453-r34-impul-side-skirts/page__gopid__5939636#entry5939636
Rear bumper due this Monday.
looks like you took the time to prep it properly, it always pays ten fold...
Yeh its funny how long goes into prepping and painting. I was prepping it slowly over 2 days. Panting - Took maybe 2 minutes per coat and did about 5 coats of each colour/clear.
Time wise, I would say
Prepping: 80%
Painting: 20%
Autobarn at Slacks Creek mixed the colours -> $50 for 500ml (Ask for $40 and they might do it for you hehe). They mix it pretty much spot on. I've tried on many angles and it doesn't look darker or lighter than the body. Looks pretty much spot on. Nice work Autobarn!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
