Hey guys few weeks ago i got my Bosch 040 installed intank, but im installing a surge tank now and using an 044 as the external pump. I get the general idea of how the system works, and what lines need to go where, But im having trouble identifying what lines are what under the car... the second hardpipe in the stock location seems to be an overflow pipe as its just a blank hardpipe that goes into the tank, but i dont know if the fuel line that went onto that hardpipe is the line that comes from the FPR or not?....
Im using this photo as a guide -
https://www.sau.com.au/forums/topic/371851-044-surgetank/
I had a look under there and i can see the lines, But they connect to hard pipes and then travel all the way down the car. I think i have my feed and return bit right but dunno what to do with the overflow bit of the circuit.
simple. hose clamps are pressure. spring clips are return.
Ok so i have the feed bit correct with my red line as that one had a screw and clamp and the other just had a spring type one i undid with plyers.. So then the blue lines can only go as ive shown here then?
edit : Also, do i have to have another fuel filter after the external pump?? wont this restrict flow a bit? and can i just steal power for the external from anywhere?
https://www.sau.com.au/forums/topic/371851-044-surgetank/#findComment-5928871
For max performance and life of the pump run a new heavy cable from the battery (easy if its in the boot but do it anyway) and fit a good earth and control the power supply with a decent relay and switch it from the original pump circuit. There are a couiple of "how to" s in the DIY section.
https://www.sau.com.au/forums/topic/371851-044-surgetank/#findComment-5928989
In regards to the return lines run the return line which is the blue one youve marked to the second nipple from the top of the surge then with the niple right at the top run that back into fuel tank where the return originally was connected.
With regards to the extra fuel filter i done run one, the stock one will be enough as your feed pumP filters it through its sock then the 044 will also filter through its inbuilt one.
https://www.sau.com.au/forums/topic/371851-044-surgetank/#findComment-5929066
Isn't the setup:
Top - return from fuel rail
2nd top - overflow to fuel tank
3rd top - inlet from fuel tank
Bottom - outlet to pump to rail
Nah the top is overflow since you want it only returning to the tank when the surge is full in order to try and keep the surge tank full at all times.
https://www.sau.com.au/forums/topic/371851-044-surgetank/#findComment-5929264
The idea is not to keep the surge tank full. The surge tank is really a "de-aeration system", to prevent the engine ingesting air because of fuel surge in the fuel tank, or because of air "dissolved" in the fuel. It is highly unlikely that the surge tank would ever get anywhere near empty enough to experience fuel surge.
https://www.sau.com.au/forums/topic/371851-044-surgetank/#findComment-5929304
ok just had another look under the car...and i thought there was only 2 fuel lines, one going to rail and one coming back, but there is 1 more line that just goes from *somewhere* into the top of the fuel tank.... Do i just leave this one alone as im assuming its an overflow?
https://www.sau.com.au/forums/topic/371851-044-surgetank/#findComment-5929358
everyone has different ideas on which nipples should go where. personally i have the top to return, 2nd is return from the rail, 3rd is feed from tank and bottom is obviously always gonna be the feed for the main pump.
main reason i set it up like that was to try and keep the fuel in the surge tank as cool as possible as i was having issues with the pump cavitating on hot days.
https://www.sau.com.au/forums/topic/371851-044-surgetank/#findComment-5929464
Probably the line back from the carbon canister. So you can leave it as is.
https://www.sau.com.au/forums/topic/371851-044-surgetank/#findComment-5929538
Guys just want to confirm once again before i actually bolt everything in, as i went and got all my required fuel hoses, fittings and clamps today.
The line circled in red there, do i go from surge tank over flow into that hard pipe, and then the fuel hose that WAS on there goes to the surge tank as well ?
the other line under the car that i said goes to tank and looks like another overflow also goes to what feels like a plastic container INSIDE the fuel tank...
https://www.sau.com.au/forums/topic/371851-044-surgetank/#findComment-5940964
yes, hook up the overflow on the surge tank (highest port) to that port circled in red. hose that was on there goes to the 2nd or 3rd fitting on the surge tank.
any other lines such as the breather, leave as per factory. those 2 hoses on that lid are the only 2 on or in the tank that need to be changed.
https://www.sau.com.au/forums/topic/371851-044-surgetank/#findComment-5941171
Ok well almost done then. I have 2 lines different though, i have that overflow on the 3rd port from the bottom, above the port that fills the surge tank, so i need to switch them around. Which is GAY cause i just spent 60$ on fuel injection hose and cut it up to size now i gotta go spend more lol
https://www.sau.com.au/forums/topic/371851-044-surgetank/#findComment-5941217
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
