Hey guys I have a set of tien coilovers in my r33 gtst theyve always been stiff since i got the car. I dont realy know to much obout coilovers but is there a way to soften them up? i know for a fact there is no dampner contril on it there just plain height adjustable coils. Also ive been told that they may be screwed from the previous owner having the car to low but at the same time people have told me that the spring rate is to stiff, like i said dont know much about coils if anywone could give me some useful info id be happy thanks =D
https://www.sau.com.au/forums/topic/371919-stiff-shocks/
piss them off and use bilstein shocks with kings/whiteline or eibach springs. get extra circlip grooves for height adjustment. Or have sleeves fitted to them (ie HSD sleeves) for full height adjustment.
even the basic BC BR coilovers will be better than your Teins (ride quality wise). no doubt your tein's are valved like shit and are probably tired, plus springs rates to suit a jap touge car (much like the Teins I've just filed under B for bin)
I even think Tein super streets are pretty average. I fitted some to a WRX I drove for around 6 months, okay but didnt feel sweet like bilsteins. I also drove a 33 gtst a while back, 4kg springs all round (what they come with) and car felt bouncy and wrong.
to answer your question they are not worth buggering around with unless they are top of the line Tein's, then getting someone like Race Pace to tweak them would be a good option but if they are just HR's or HA's or what ever not worth it IMO.
Cheers, Jack
https://www.sau.com.au/forums/topic/371919-stiff-shocks/#findComment-5929814
If they're not leaking you could think about throwing some softer springs at them and resetting the height to something sensible, but you may then have too much dampening for the spring rate.
Probably better to get a new set. Spring rate is very important. Find out what rate your current springs are (check the sticky, not sure if its still active tho) to give you some perspective on what to go for. Or else find someone with, say, 5 or 6kg front/4kg rear in a brand you can afford and see if you like them.
The bounciness in the ones you tried could have been stuffed shocks or ride height too low causing bottoming out on the bump stops, so if you can, find another 4/4 to try.
https://www.sau.com.au/forums/topic/371919-stiff-shocks/#findComment-5930949
interesting how you got so many responses, ive been struggling with my teins for ages, tossing up wether to get rid of them or change springs, mine are HA and damper adjustable, obviously the springs are very stiff.
Ive decided with mine that i will just put up with a little bouncing here and there, ive set the damper to what i think is ok, dam good on a perfect road, but bit uncomfortable on a rough road, and dangerous on a rough fast road taking corners..
but id rather put that money toward a gt30 than stuff around buying more coilovers, they can be bearable if you can adjust the damper , definitely no good at the drags lol..
ive found they are better when the car is lower rather than higher, the spring is longer if its lower.. correct me if im wrong but thats where ive found it to be best..
if you were in brissy i could show you how mine handles.. but if you cant adjust damper then it could be bit hopeless.
Edited by SliverS2
https://www.sau.com.au/forums/topic/371919-stiff-shocks/#findComment-5932285
Before you dump your shocks go to a Tein dealer and get a price to have them revalved (if in fact it is the shocks that are the problem and not your springs). A proper suspension place should be able to work out the spring rates and tell you if they are too hard.
https://www.sau.com.au/forums/topic/371919-stiff-shocks/#findComment-5932751
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
