hey all, having some dramas with my car and want some opinions, im struggling to narrow down what the issue is.
its running really rough, it seems to be hunting, and possibly burning oil (im yet to suss out the colour of the smoke properly, however it smells like fuel).
Oil and water are the colours and at the levels that they should be, the cooling system is not pressurising straight away and its not steam coming form the exhaust so im fairly confident that its not the head gasket.
the weekend before last i drove out to port augusta and back (surely getting some dirty ass fuel along the way). My car is my daily driver, and when i got in on wed arvo to drive home from work is when it started missing/runnig rough, i was quite low on fuel at this point.
I have swapped out the plugs this arvo, and they were really fouled. put in a set of new plugs and it runs the same (however i did not gap them cos i dont have my feeler gauges at my gf's place). on visual inspection the coilpacks seem ok, but i really have nfi what im looking for to spot a faulty coil pack. in addition the AFM appears clean and ok.
my question is, what can lead to those symptoms of hunting, running rough and being smokey? rings? dirty injectors? dead coil/ignitor pack? dead AFM?
im grateful for any help i can get!
https://www.sau.com.au/forums/topic/372049-missfirerunning-rough-and-hunting/
  • Replies 47
I had the same issues in my S15 - turned out I had gotten a dirty batch of fuel (from Southern Cross - never again) and it had clogged up the intake sock on the fuel pump 80%, so not enough fuel was getting through. It didn't seem to lean out, but rather hunted and had similar symptoms to yours. Ended up having to replace the fuel pump and remove the fuel tank to have it steam cleaned internally - there was 1cm of gunk/mud in the bottom of my fuel tank! And that was when the car was only about 30,000km old.
my immediate reaction is AFM, but it could well be the dodgey fuel.
then again, I run mine down to vapour basically every time and thats never happened lol.
also, check all the intercooler piping.
if it was coilpacks,
start the car, pull one clip off at a time and the one that DOESNT make a difference is the one thats not working.
if you disconnect a WORKING coilpack it will become worse.
thanks for the input guys,
first up i'll suss out the joiners and cooler piping to try and find obvious flaws... reckon i will replace the lot as they are quite old and some appear a little perished.
failing that i'll play the coil pack game (am i likley to cop 12 volts up my arm pulling the loom from the coils?).
if that tells me nothing i'll pass it on to a mechanic to suss out the fuel system etc, i dont fancy being covered in petrol again.... got enough of that from that ke36 wagon i had
as for the smokey exhaust/fuel smell, a hole of some sort in the intake, faulty afm, or faulty coil pack makes sense.... the hole in the intake or faulty afm means the ecu could think there is more air than there really is going into the car, and would pump in more fuel than necessary which would make its way out the exhaust. coil pack not operating i suppose would have a similar effect.
nah its a gts-t matt. thanks for the offer :)
the piping is fairly ugly & mismatched... could do with a re-vamp. my fmic uses the stck piping positions similar to a cooling pro one. wont get too far ahead of myself tho... will pull it apart and have a good look at it all.
i have not noticed it leaning out, i have been driving like a nanna cos my clutch is about to let go (soon as i hit boost it slips :( ) *****looks at steve for clutch hookups*****
changing the fuel filter only takes a couple of minutes to do, good idea to check if the fueltank/pump sock is clean if you find your filter is clogged.
taking off individual coilpacks as the car is running wont result in a shock, good idea this one to see if its a dodgy coil.
If your coilpacks are breaking down you could try a cheapfix method..... purchase selleys 401 industrial strength hitemp silicone sealant ($15 bunnings) use a corking gun ($2) and lather the coilpacks in the silicone- helps top wasted arc, but only generaly for boost applications (if your coilpacks are one the way out you're better off purchasing a replacement set).
Clean air filter (pod or panel), clean your Air Flow Metre with contact/brake cleaner spray & make sure your contacts are good. There is a DIY-guide on how to fix faulty AFM's in the relevant section, definately worth while to source a spare afm and testdrive to eliminate this potential problem.
Perhaps after this try a compression test; worse case could be glazed cylinder wall. Start with the basics and work your way from there...
Cheers Brendan, thats some good info. l think the fuel filter is a must, if not only beacuse of how long it has been in the car.
after sussing out the cooler piping (im guessing it would be an obvious leak for it to run so rough at idle). i'll attack the AFM
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
