hey guys,
thought someone might know a little about these, bought a new blitz intercooler kit on the cheap as it come with no instructions and a silicon missing. silicon was easy to obtain but the instrustion being gone and my inability to wing it like i thought i would have me a little lost, below is a pic of all the bracketry that come with the kit and also a pic of the front of my car. if possible could someone please point out what goes where.
cheers adam
p.s. i have also posted this on ns.com but was hoping for a faster response on here as im mid assembly
https://www.sau.com.au/forums/topic/372291-blits-s13-intercooler-install-help/
No idea on a Silvia but generally hoses will dictate where the i/c sits and then you look to see where brackets can attach. If its not a custom set up you may need to bend brackets, make up new ones or weld mounting tabs.
I like the cooler as high as I can mount it, right up close to the lights.
The pipework will fall into place.
I made my own brackets for the bottom, ground off the two top tapping blocks and used a single mount at the centre instead which raised it up approx 25-30mm.
The black chassis car is showing the position for standard brackets.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
