56 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 145
Posted Images
Yes, I should have made that clear, I'm in Kingston for people that want to pickup their stickers.
God damn I'm in Kingston all the time lol. I thought you were living out at Port Arthur. Guess you'd have to be happier living a bit closer to everything now.
Hey guys, I know I'e been slow with this but my mate has been really busy so it took him a while to get the design together. Obviously Zoid has got some stickers on the go which is awesome, but I thought I'd still post these options up for anyone who is after something a little bigger. These ones are also vinyl cut stickers.
The one on the left is 155mm x 50mm and will be $10, the one on the right is 330mm x 105mm and will be $20. The final stickers will be in the correct colours, with the lettering and map in white except for the S in SAU which will be red.
If people are keen I will get a list going for orders.
Stickers are done now :) I'll post them out this afternoon.
because they're a multilayer sticker we have to multilayer them our selves so that's something to look forward too. Saved about $5 per sticker though :P
So it goes in this order, first the silver one, then the white one, then the red one.
They made us a red A too, not sure why... doesn't matter though.
Pics to come.
Also, they only printed 18 for some reason so I told them to make me some more so I'll have 8 spare ones now. PM me now if you want them, Limit 2 per person.
Edited by zoidbergmerc
im all for a bit of effort to save the money.
good job zoid. hats off for being bothered to do somthing self less.
+1 thanks again man. If your not keen for a bit of DIY then dont own a skyline lol. Cant wait to get these... oh and actually get my car on the road lol.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
