Item Summary: 1996 NISSAN SKYLINE GTS4/ GTR vspec 4 door, GTS door with Full vspec gtr gear Sleeper
Postcode: 4132
Odometre: 94,000 kilometres
Asking Price: $15,000
Condition: Used
Reason for Selling: dont need
Delivery Methods: PickUp
Contact Info: PM ME
Extra Information:
hey guys this is a GTS R33 with a full 33 GTR vspec running gear and rb26
at the moment its E.O.I
and im up for offers over 15,000 alot of work has gone into this car
Biggest sleeper
pretty much stock
Nismo dash
brembo's
front lip needs some paint but only thing wrong with it
full Autech GTR body kit all round with a 33 gtr front conversion
sick ride
Edited by navanskyline
https://www.sau.com.au/forums/topic/372438-gtst-4-door-vspec-gtr-sleeper/
I'd put money on it being an Autech 40th Anniversary GTR sedan.
http://www.jbskyline.net/R33/4door/Showroom/
I can't see a guard roller doing such nice work to the rear doors and guards...
Your car isn't this one is it?
http://www.boostcruising.com/forums/index.php?showtopic=227248&st=0
If it was original it would be worth more than a run of the mill R33 GTR.
If it is with the guards and doors and stuff, FFS someone go look at it and give us some feed back.
Or bring it to Sydney and I might buy it.
http://j-spec.com.au/featured/1998-Nissan-Skyline-GTR_sedan_Autech_40th_Anniversary-15503.html
it has the full Autech kit guards and the rear doors done not a autech one and no its not the one off boost its fresh from japan
for the work that has been done to it
its fairly cheap
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
