So my heater core shat itself and pretty much rooted the carpet, I have pulled it out and was just going to get rid of the sound deadening and paint it black. but, a mate of mine reckons its illegal to have no carpet, i dont see why it would matter, its not tlike the carpet can protect you from anything other then noise.
Anyone know 100% what the go is?
The car is going to be only street driven on weekends or to the track so I dont care about noise hence why I want no carpet or deadening and thought now was the best time to rip it all up as I have no choice now >_<
https://www.sau.com.au/forums/topic/372600-no-carpet-legal/
These days, any modifications are deemed illegal jus cos Police and Vicroads doesn't always agree on what is legal or not.
I say, rip the carpet off, if you're in need of one, you can always get another one off wrecked R32.
https://www.sau.com.au/forums/topic/372600-no-carpet-legal/#findComment-5942384
That being said, I never heard of one get defected (or told off) for no carpet.
Some cars doesn't have one from factory so I'd say you should be right for not having a carpet.
https://www.sau.com.au/forums/topic/372600-no-carpet-legal/#findComment-5942457
At a very least you would want to make sure there are no wires or cables uncovered. As mention some cars/more commercial come with vinyl/rubber mats that would not be any more slippery than the metal.
Im sure there would be police that would hand out a defect thou
https://www.sau.com.au/forums/topic/372600-no-carpet-legal/#findComment-5942549
It's not as though the metal is bare, even under the paint it has that grey protective coating on it.
thats true. but i think for the fact that a "law excuse" would be there is more chance of you getting electricuted without carpet than with it
https://www.sau.com.au/forums/topic/372600-no-carpet-legal/#findComment-5951228
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
