23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
It's all good, someone's turbo will blow up and then you'll all be too busy discussing the idea of getting some random jap dude to tune your car for you in some faraway land.
Our turbos are 10 years younger than your toyotas, remember?
We might be discussing how to properly tune our cars, unless OG want to become Greddy or HKS tuners...
  • Replies 211
So because your Volvo is newer the turbos blow earlier????
Not sure about 10 years either, my car is s June 2000 build. Was your car built last year??
And no OG performance will not be doing tuning, I am too much of a Neanderthal to understand all them fangdangled electronic trickery devices.
Hi guys first post, im in for a cruise any sunday should be ok i work sundays so will need some notice to cover my shift at work +1 x M35 to the list, gimme an email so i can organise will check out the forum again soon.
Awesome. Be good to outnumber the C34s for a change!
BTW you can subscribe to the forum so you get email alerts, handy feature if you don't check them that often.
Dont care about the date, all are good & clear of the Royal Adelaide Show (2nd - 10th Sept)
We are very much looking forward to the drive...lets hope the weather is kind to us (this time)
ALSO we have a link with the Legnums forum now...if you want to invite them to join us ???
What are your thoughts ?
"the OLD peeps"
"the OLD peeps"
I'm not fussed, what do the other wagon lovers think??
Hey guys!
Keen as for this one ! 11th is sweet but others sound work! Sooner the better 
So count another C34 to the list  !
Missed all the others and dying 2c some of there stags in action!
Trying to decide in turbo,injectors etcs 
Any S2 Autos with after market turbos coming ?
Do I dare ask the question ... Who has the quickest stag
Here  just thought I would chuck it out there!
LOL, lets just say the fastest Stag isn't a 35!
I think we should invite the leg's
Says who? :nyaanyaa:
Happy with the Legs to come. Ancient POS can play with the C34s while the M35s run along ahead!
baaa haaaa this thread is gold now, " mine is bigger""but mine is newer so must be quicker"lol im loving it i can see a stag lala track day comming up. i know big fella &dream15 and my self would be keen for a laugh,right guys. should sort the men and women from the keyboard wariors. and hell yeah invite the legnum boys to on the cruise maybe could be the start of an performance import wagon club lol
Can everyone that is keen for the cruise please make sure you vote on the poll, i'd like to get a date locked in ASAP before this thread turns into fisticuffsnyaanyaa.gif
I'll be in contact with Olds mark and the Legnum crew to extend the invtation, at least then the old faithful straight 6 power can show these Bent 6 kids how its done!
