As per title
Geniune Nissan OEM brand new in box RB coil packs. Come as a set of 6 for RB's
OEM Nissan part no: 22433 60U01
OEM Nissan part no: 22433 60U02
Both part numbers available in complete sets of 6
$430 - postage within Australia included in price
7 sets in total available - PM is best contact
Cheers
Jono
Edited by jonnyo
https://www.sau.com.au/forums/topic/372753-nissan-oem-rb-coil-packs-brand-new/
These coils do not have the built in ignitor and only suit
R32 GTR
R33 GTR
R32 GTST
R33 GTST Series 1
Please note the 2 part numbers in above - these are the only part numbers available
Cheers
Jono
Hi Guys also have 2 sets of series 2 coil pack sets BRAND NEW!
part no# 22448-25U00
same price $430 including delivery!
Edited by jonnyo
Hi guys
Just to clarrify I have
6 (6 per set)complete sets of RB coil packs to suit BNR32 and BNR33 and series 1 GTS-t
2 (6 per set) complete sets to suit R33 GTS-t series 2
All sets are $430 inc delivery with in Aus or $400 pickup form Brisbane Southside. Get in quick to secure these awesome brand new OEM coil packs.
Do a search to compare these to aftermarket brands - they perform awesome!
Cheers
Jono
Sorry on the late reply been flat out!
needed some for mine - found them at an awesome price and took what they had. passing on the savings to fellow Skyliners. Great price peeps snap em up while they are still here :)
nissan want big $$'s for these and as per the threads the geniune coils do a bloody awesome job!
I need a set for rb20 how long will they take to get sent?
Once the money lands in the account they will be sent that day or the next day depending on how busy i am with work.
wanted to give some props to jono.. he is away in sunshine coast yet he set me up on the same day i rang to pop up to a friends and get the coil packs right away... great service hey... super good guy, not a car ego guy.. super helpful.. and beautiful coils.. wish i never wasted money on other coils.. when these outlasty splitfire. i havent heard of a 15 year old car with splitfire running it.. lol... recommend getting these and saving the cash and not wasting money on other coils.. wants more power.. just gap spark plugs and tune.. hehe... hey thanx man
another happy
another happy customer here ..he delivered quick.coils are awesome as above if your deciding between splitfires yellow jackets or these oem...oem 100%...
Still got some mate? 1 set of series 1 (R32 RB26) coils to Melbourne.
Hey last set just got spoken for earlier - waiting on direct deposits to land - if sale falls through I will let you know.
Cheers
Jono
FYI For those who got the ones that ended with U01 you got the better ones :thumbsup: They are GTR ones and are better (apparently) than the U02's which were GTST
But on the bright side you all got the best coils you can get (apparently) ppl dont usually buy then though because they are normally over $1000 from nissan.
Edited by W0rp3D
Actually the 01 were on early R32 GTR and had the carbon tip. Nissan released the 02 packs with only the spring deleting the carbon tip and these appeared in later model R32's and R33's GTR. Apparently Nissan relised that the carbon tip actually didnt make a difference to the conductivity. I had 01's and now run 02's and they work perfectly on my GTR.
There are threads online about the difference's. Cheers guys and glad I could help with these coils at a fantastic price :merli:
I'll vouch for Jono, he's one of my oldest friends, top bloke.
Anyone wanting genuine coils better grab them up! It's a bargain!
Thanks mate will see you Friday with your set :thumbsup:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
