Hey guys,
I been having problems starting my R33 at cold morning, fire her up and stalls straight away, start again stalls again and for the 3rd time she fires!
Ive got Greddy Type RS BOV, this morning I decided to block it off with plate and it actually fire up first go..
Is this normal? Good or bad?
Cheers
https://www.sau.com.au/forums/topic/372942-stalling-rb25-start-up/
Not too sure with this sort of stuff. But is the BOV plum back or not? if it is leaking and not plum back then the engine would think it would be getting more air than it actually is causing it it run real rich. But idk cause yr not hitting boost at idle lol.
If I wasn't posting from an iPhone, you'd be feeling the full force of the dumbass stick.
You have created a big f**king airleak in your intake system by installing your wanker valve.
It's not meant to be there. Take it off and your problems will go away.
After reading this, I want you to SEARCH for "stalling" and "bov" and see the million threads. Learn how your car works before adding this junk to the system, creating an airleak, so you sound cool an attract cops.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
