SQ
bar x 10
40kg x 10
70kg x 10
90kg x 10
127.5kg x 5
127.5kg x 5
127.5kg x 5
127.5kg x 5
127.5kg x 5
Deficit DL
132.5kg x 5
132.5kg x 5
132.5kg x 5
132.5kg x 5
132.5kg x 5
Reverse DB Flys
10kg x 12
10kg x 12
10kg x 12
Trap Bar Bent Rows
85kg x 10
85kg x 10
85kg x 10
DB Curls
15kg x 12
15kg x 12
15kg x 12
15kg x 12
15kg x 12
15kg x 12
GHR's
10, 10, 10
Shrugs
120kg x 12
120kg x 12
120kg x 12
UDL's
64kg x 20
64kg x 20
64kg x 20
Planks
+5kg x 1min
+5kg x 1min
+5kg x 1min
  • 1 month later...
  • Replies 300
Mike do you only focus on strength training?
What are your goals?
some decent lifts in there though.
Monday: "I wanna get massive"
Tuesday: "I wanna get lean"
Wednesday: "I wanna get fookin strong"
Thursday: "I wanna get super fit"
Friday: "I wanna be a body builder"
Saturday: "meh, f**k this shit"
Sunday: "What will I do next week?"
^^^ pretty much describes my shitness
I just do what I can, which is what I enjoy - squat, bench, deadlift, row, ohp, curl
Truth is I'm so busy with work and pumping much mental energy into it come 6pm I rarely feel like going to the gym and training.
Edited by GHOSTrun
SQ
bar x 10
40kg x 10
70kg x 10
90kg x 10
120kg x 10
140kg x 5
140kg x 5
140kg x 5
140kg x 3
BP
bar x 20
40kg x 20
60kg x 5
80kg x 5
80kg x 5
80kg x 5
Deficit DL
70kg x 5
90kg x 5
120kg x 5
120kg x 5
120kg x 5
140kg x 2
23/11/12
BP
bar x 20
40kg x 20
60kg x 10
80kg x 5
80kg x 5
80kg x 5
82.5kg x 1
85kg x 1
87.5kg x 1
90kg x 1
26/11/12
SQ
bar x 10
40kg x 10
70kg x 10
120kg x 10
140kg x 5
140kg x 5
140kg x 5
BP
bar x 20
40kg x 20
60kg x 10
80kg x 2
80kg x 5
80kg x 5
80kg x 5
80kg x 5
80kg x 5
3/12/12
Deficit DL
70kg x 10
100kg x 3
120kg x 3
150kg x 5
150kg x 5
150kg x 5
Trap Bar Bent Rows
80kg x 10
80kg x 10
80kg x 10
DB Bench Press
25kg x 10
25kg x 10
25kg x 10
DB Curls
20kg x 12
20kg x 12
20kg x 12
Planks
10kg x 1min
10kg x 1min
10kg x 1min
GHR's
  • 1 month later...
16/1/12
SQ
bar x 5
30kg x 5
40kg x 5
50kg x 5
60kg x 5
70kg x 5
80kg x 5
90kg x 5
100kg x 5
110kg x 5
120kg x 5
BP
bar x 5
25kg x 5
30kg x 5
35kg x 5
40kg x 5
45kg x 5
50kg x 5
55kg x 5
60kg x 5
65kg x 5
70kg x 5
75kg x 5
80kg x 2
Single Arm KB Rows
24kg x 10
24kg x 10
24kg x 10
24kg x 10
24kg x 10
18/1/13
Deficit DL
70kg x 5
80kg x 5
90kg x 5
100kg x 5
110kg x 5
120kg x 5
DB Incline BP
25kg x 8
25kg x 8
25kg x 8
Single Arm KB Rows
24kg x 10
24kg x 10
24kg x 10
24kg x 10
24kg x 10
MP
40kg x 5
40kg x 5
40kg x 5
40kg x 5
40kg x 5
DB Curls
15kg x 10
15kg x 10
15kg x 10
Planks
20kg x 1min
21/1/13
BP
bar x 5
30kg x 5
40kg x 5
50kg x 5
60kg x 5
70kg x 5
80kg x 5
70kg x 5
70kg x 5
70kg x 5
70kg x 5
70kg x 5
SQ
bar x 5
40kg x 5
70kg x 5
90kg x 5
120kg x 5
120kg x 5
120kg x 5
120kg x 5
120kg x 5
Single Arm KB Rows
28kg x 10
28kg x 10
28kg x 10
Planks
25kg x 1min
22/1/13
Incline DB BP
15kg x 10
15kg x 10
15kg x 10
20kg x 10
20kg x 10
20kg x 10
25kg x 8
25kg x 7
Deficit DL
70kg x 5
80kg x 5
90kg x 5
100kg x 5
110kg x 5
120kg x 5
130kg x 5
140kg x 5
145kg x 1
DL
150kg x 1
155kg x 1
160kg x 1
Curls
3 sets
DB MP
15kg x 10
15kg x 10
Single Arm KB Rows
32kg x 5
32kg x 5
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
