  • 2 months later...
  • Replies 183
Hey, Jetwreck,
i'm wanting to buy one of these shift kits.
Leon(Commsman) took me for a run recently and i,m wrapped.
Are you looking to do another buy shortly,or should i just order from Summit.?
I can,t do the job myself, but there is a reputable auto specialist (Ron Hill Automatics)up here
on the Sunshine Coast who will it for $500 plus Matic j
Graham.
just order it from summit.....$500 is a f#$king ripoff for the install though! I do it for $250 not including oil!....if his a pro and cannot do it in under 3 hours theres a problem.
Edited by Jetwreck
I agree. If you don't mind your car being out of action for the duration of the shipping to Sydney & back, get Craig to do it.
If you tee it up with him, he normally has the VB turned around same day. Easy job to remove the VB & reinstall, just a bit messy.
However, if you can't be without the car for more than a day, then I guess the extra cost can't be avoided. Unless you do the whole lot yourself.... ;)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
